Craftsman Router Shaft - Router Forums
post #1 of 6 (permalink) Old 04-22-2015, 09:25 AM Thread Starter
First Name: Ray
Default Craftsman Router Shaft
I have a craftsman router attached to a sears router table. Recently I have noticed, the shaft moving up and down about an 1/8 of an inch. Is this normal??
Paden is offline
post #2 of 6 (permalink) Old 04-22-2015, 10:52 AM
MikeMa's Avatar
This is not normal. Is the whole router moving up and down in the table, or the spindle itself? If it is the whole router, most likely something needs tightening. If it is the spindle, it sounds like a bearing went bad.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 6 (permalink) Old 04-23-2015, 08:56 AM Thread Starter
First Name: Ray
Mike, thank you for your quick reply. the spindle is the culprit. I'm in the process of purchasing an new router. But, I'm wondering if this one is dangerous to use? I would like to use this router for small projects. What are your thoughts?? Thanks again. Paden
Paden is offline
post #4 of 6 (permalink) Old 04-23-2015, 10:31 AM
MikeMa's Avatar
I wouldn't want to use this router this way. It maybe possible to replace the bearings on that router, but I think you are going the best route with getting a new one.
-Mike
MikeMa is offline
post #5 of 6 (permalink) Old 04-23-2015, 10:40 AM Thread Starter
First Name: Ray
Thanks Mike!
Paden is offline
post #6 of 6 (permalink) Old 04-23-2015, 12:29 PM
There are very few routing operations you can do with it doing that anyway. Normally the top end just slips into the bearing but sometimes the bottom end has a keeper plate to hold the bearing into its cup in the casing. Is there a keeper plate and is it tight? Otherwise the bearing is probably worn out.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Help with Craftsman Router model 135.17508 bsturpin Tools and Woodworking 3 08-02-2012 07:45 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
