Heavy or light - Router Forums
post #1 of 8 (permalink) Old 04-27-2015, 08:20 PM Thread Starter
First Name: Barry
Default Heavy or light
Won't get into brands as it's irrelevant. I've been using a lighter, older router I inherited as a table mounted router and it's served me well. I recently bought a newer, much heavier model from an acquaintance that was moving. I'm of two minds - mounting the heavier one on the table and using the lighter one to freehand as it's more maneuverable, or continuing to use the lighter one as the table mounted, and using the heavier one because of it's stability in freehanding. Am I overlooking the obvious? Thank you.
overfifty is offline
post #2 of 8 (permalink) Old 04-27-2015, 10:39 PM
Ghidrah's Avatar
First Name: Ronald
I'd go with heavy table light hand. If you come up with some heavy duty routing that requires a 3 HP pull it out for the job, I did it for yrs.
Ghidrah is offline
post #3 of 8 (permalink) Old 04-27-2015, 11:18 PM
I agree with Ron. More power for the table.
post #4 of 8 (permalink) Old 04-28-2015, 05:11 AM
I agree with Charles, who agrees with Ron...
I sometimes use a Triton TRA001 or a Makita 3612C freehand and have not found the weight to be a problem, if you are routing so that the router rests on the work.
Sydney, Australia
jw2170 is offline
post #5 of 8 (permalink) Old 04-28-2015, 10:22 AM
PhilBa's Avatar
First Name: phil
I actually like a heavier router for hand held work tough there are cases (like trim routing) where lighter makes more sense. That said, put the more powerful router in the table as you will get better results for table mounted routing with that. Powerful vs heavy - they may be basically the same thing but it's the power that makes the difference in a table.
PhilBa is offline
post #6 of 8 (permalink) Old 04-28-2015, 10:47 AM
First Name: Buck
I would say in general the heavier/more powerful one in the table BUT....... I once watched a video of a person doing inlay work in which he preceded to use a heavier router for taking out the bulk of material because he felt it was easier to control when free handing. I think it is really a personal preference.
Just because one is heavier than the other doesn't mean it is more powerful. I have older routers that aren't as powerful as my newer ones yet they are much heavier. There have been some major advances in router technology over the years that increases power while decreasing the weight.
Buck
BOjr is offline
post #7 of 8 (permalink) Old 04-28-2015, 11:38 AM
Ghidrah's Avatar
First Name: Ronald
I've done similar to BOjr, Lam trimmer, T4 and 690 for the fine work and 690 and 7537 for hogging. Having a couple 3 routers can save a project in quality and time savings.
Ghidrah is offline
post #8 of 8 (permalink) Old 04-28-2015, 01:46 PM Thread Starter
First Name: Barry
Thanks to all. Table mounting the heavier router sounds unanimous. Cheers, Barry.
Endgrain Project #3 Light Box Herb Stoops Show N' Tell 26 01-19-2015 10:01 PM
Homemade Drawer Slides, Heavy Duty and Light JOAT Project Plans and How To 13 10-20-2013 09:22 AM
Aging Cherry Using Artificial Light? BigJimAK Tools and Woodworking 13 09-06-2010 12:57 PM
