better clamp for porter cable routers - Router Forums
post #1 of 6 (permalink) Old 05-08-2015, 02:21 PM Thread Starter
First Name: Richard
Question better clamp for porter cable routers
Some time ago I saw a recommended clamp for the porter cable router that was am offset lever. Does anyone know where such a thing can be found. Thank you
WildStock is offline
post #2 of 6 (permalink) Old 05-08-2015, 06:31 PM
Do you mean something like these from Lee Valley? Cam Clamp Mechanism (1/4-20 Thread) - Lee Valley Tools. If so they are one source but Essentra would also be a source and have a wider selection. If you are thinking of something different Essentra would be a good place to look for it. They have a huge selection of jig and tooling parts.
post #3 of 6 (permalink) Old 05-08-2015, 08:14 PM
PhilBa's Avatar
First Name: phil
I posted this a while ago. You might want to try the bicycle ones since they curve around a bit more.
PhilBa is offline
post #4 of 6 (permalink) Old 05-09-2015, 08:22 AM Thread Starter
First Name: Richard
Yes, That is exactly what I was looking for.
Thank You
post #5 of 6 (permalink) Old 05-09-2015, 08:40 AM
Here is another option using a clamp handle. I'd seen this in a photo on Alan Warner's web site, but Serge did an article on his web site. I bought the clamp and did the modification, it works really well, about 90 swing of the handle from loose to fully locked. The standard 1/4" washers were too big so wound up taking #10's and reaming out the hole. Way too much work so I ordered a steel spacer and ground a flat on the back side where it fits against the body of the base.
Tom.
tomp913 is offline
post #6 of 6 (permalink) Old 05-09-2015, 09:46 AM
The seat post cam clamp from a bicycle is almost a perfect fit. Bicycle shops usually have a box of used ones they will sell very reasonably just to get rid of them. I got 3 for my PC routers for $7 total. Be sure to get the bolt with them, they are usually metric thread.
senebraskaee is offline
Porter Cable plunge router motor lock wizardgmb General Routing 3 01-14-2015 09:48 AM
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
Porter Cable Help Needed Packrat8487 New Member Introductions 8 12-09-2013 12:26 PM
Routers (2) stopped working AxlMyk Lobby 9 11-12-2012 08:43 PM
Porter Cable routers Recall Learning Herb Tools and Woodworking 3 03-07-2006 07:04 AM
