Router Lift Issues - Router Forums
 8Likes
  • 2 Post By Stick486
  • 2 Post By RainMan 2.0
  • 2 Post By DesertRatTom
  • 1 Post By GregLittleWoodworks
  • 1 Post By timbertailor
post #1 of 9 (permalink) Old 05-11-2015, 04:51 PM Thread Starter
First Name: Ken
Default Router Lift Issues
New to the forum. Hoping someone can shed some light on an issue I'm running into with my router lift. I can set the height I need but once the router is on for a brief time the bit will drop or raise in height. Original lift was a Jet Xacta lift made by Jessum. Thought it was an issue with the lift itself so I purchased a new lift from Woodworkers Supply this weekend. Finished setup this afternoon and the problem is reoccurring with the new lift. Router motor is from a Porter Cable 690 with 1/2" collet. Issue happens with multiple bits. Almost seems as if the router spindle is out of tolerance. Any thoughts?
kbgoodex is offline
post #2 of 9 (permalink) Old 05-11-2015, 05:01 PM
WTB it's the routers collet...
days end or just needs maint...
timbertailor and billyjim like this.
post #3 of 9 (permalink) Old 05-11-2015, 05:33 PM
Welcome to the forum, Ken.
Sydney, Australia
jw2170 is offline
post #4 of 9 (permalink) Old 05-11-2015, 07:35 PM
Welcome Ken. I would have to agree with Stick. The most likely culprit is the collet.
post #5 of 9 (permalink) Old 05-11-2015, 08:01 PM
RainMan 2.0's Avatar
And Ken don't get Stick started on Porter Cables quality control
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 9 (permalink) Old 05-12-2015, 06:17 AM
Try putting a small rubber grommet into the collet. About 1/8th thick. Then you can bottom out the bit on the grommet which may help. If that fails, replace the collet. If that fails, get a Bosch.
billyjim and Stick486 like this.
post #7 of 9 (permalink) Old 05-12-2015, 06:44 AM
normie2's Avatar
First Name: larry
Default bit adjustment
Are your bit shafts clean? Also, what brand bits are you using.
normie2 is offline
post #8 of 9 (permalink) Old 05-12-2015, 10:10 AM
GregLittleWoodworks's Avatar
First Name: Greg
Weccome to the forum ken
If it happens with multiple bits then it would appear to be the collet. I had a problem with a 1/2" roundover bit slipping in my Bosch 1617 but it didn't slip with any other bit. Replaced that bit and problem solved.
since then I have replaced my collet with a Musclechuck and it is even more convenient for bit changes and none have slipped.
RainMan 2.0 likes this.
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
post #9 of 9 (permalink) Old 05-13-2015, 07:07 PM
First Name: Brad
I am currently taking bets.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Router for table & maybe a lift cobragrover Table-mounted Routing 9 01-18-2012 05:22 PM
Router Lift Questions jame21 General Routing 3 11-03-2011 10:05 PM
Router Lift for Bosch RA 1180 Router Table DelVan Table-mounted Routing 3 04-14-2010 12:48 AM
