Corner Radius Template - Router Forums
 12Likes
post #1 of 15 (permalink) Old 05-12-2015, 08:23 PM Thread Starter
Default Corner Radius Template
I've looked to buy factory outside corner radius jigs for larger radii and have been unsuccessful in finding them. I am going to guess that homemade jigs are my best option.
Any suggestions on where to find them for purchase or how to make them?
Thanks in advance
Rajuncajun is offline
post #2 of 15 (permalink) Old 05-12-2015, 08:39 PM
Thanks in advance
OneTime Run Radius Quick Jig
Simple corner radius jigs
OneTime Tool - Corner Jig
post #3 of 15 (permalink) Old 05-12-2015, 09:03 PM Thread Starter
Thanks....but looking for something for larger radii, maybe in the 2-3" radius range. Woodpeck ran those as one time tools and they too do not make them for larger radii.
post #4 of 15 (permalink) Old 05-12-2015, 09:17 PM
For larger radii, I found that a circle jig usually works as well. I did make myself a set for 2 to 3 1/2" from 1/4" MDF though.
John Schaben
jschaben is offline
post #5 of 15 (permalink) Old 05-12-2015, 09:27 PM
circle jig and make your own templates......
Model-200 |
post #6 of 15 (permalink) Old 05-13-2015, 06:23 AM Thread Starter
Thanks! I guess my question would be how to make corner radius templates using a circle template. What is the slickest way to transition from the tangent point of the circle to the two straight portions of the circle template? Make sense?
post #7 of 15 (permalink) Old 05-13-2015, 09:50 AM
PhilBa's Avatar
First Name: phil
It seems to me that you could use a router with bushings to make some of the templates. Just run the bushing against a right angle template. For example for 1/4" radius, use a 3/4" bushing and 1/4" straight bit. You might be able to make larger rings to slip over the bushing and get larger radii. It would definitely be tangential at the ends of the curve.
edit: and you could get 1/2" by using the 1/4" template to make the next template. So, in fact, you can make any radius template that is a multiple of your smallest gap between bit and bushing lip. Might be a bit of work to get to 3" radius 1/4" at a time though!
PhilBa is offline
post #8 of 15 (permalink) Old 05-13-2015, 10:05 AM
Gaffboat's Avatar
First Name: Oliver
I use a set from Woodhaven that lets you cut 3/4", 1", 1-1/4", 1-1/2", 1-3/4", 2", 2-1/2" & 3" outside radiuses. The templates are made out of 3/8" mdf and each template is made to accept little guide "feet" that align the template with the edge. The Woodhaven 3650 Outside Radius set is available on Amazon.
Although I haven't used the set much, it was very helpful in making rounded corners on the main table top of my fold-down router / work table.
Gaffboat is offline
post #9 of 15 (permalink) Old 05-13-2015, 10:22 AM
GregLittleWoodworks's Avatar
First Name: Greg
I have had many templates custom made by http://www.routertemplate.net
The also make quite a few stock size templates. All are made of top quality and accurate. I have been very satisfied with them all.
Rajuncajun and Herb Stoops like this.
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
post #10 of 15 (permalink) Old 05-13-2015, 11:15 AM Thread Starter
Thank you, sir!
jig for a straight line to an outside radius corner jojay Jigs and Fixtures 3 10-27-2014 12:30 AM
How to route a corner radius Raystafarian Guide Bushings and Templates 4 03-12-2013 05:28 AM
corner radius bluebonnetcabins General Routing 33 08-24-2010 01:32 AM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 05:51 PM
