Angled Lid? - Router Forums
post #1 of 5 (permalink) Old 05-13-2015, 05:57 PM Thread Starter
mbar57's Avatar
Default Angled Lid?
So, I've pretty much got your standard box down pat?! So I would like to try my hand at a box with an angled top. Could you all help me out with how to figure the compound miters needed to accomplish this. Thanks in advance for your help!!
mbar57 is offline
post #2 of 5 (permalink) Old 05-13-2015, 06:02 PM
what are you cutting the angles with...
the .xis/.odt/.ods/etc plug in spread sheet won't load...
will have to email if you want it... your choice of format..
Stick486 is offline
post #3 of 5 (permalink) Old 05-13-2015, 07:15 PM Thread Starter
mbar57's Avatar
Thanks, Stick!! I have a nice set of beveled router bits, I'd like to break in, but I could use my miter saw. Do you have any of those files in English though? No, just kidding that is what I was looking for.
mbar57 is offline
post #4 of 5 (permalink) Old 05-13-2015, 07:26 PM
got plug in calculators but but I'd have to email because they won't post..
found the links...
Compound Miter Saw Calculator
Compound Angle Calculator ::: Mitered and Butted Joints
Stick486 is offline
post #5 of 5 (permalink) Old 05-13-2015, 10:38 PM
I trust you are using a router table...
the table saw calculator and you should be good to go...
the angle setting for the blade will be angle on the router bit...
Stick486 is offline
Rabbet for box lid phillipsted General Routing 6 11-11-2014 08:18 AM
Making angled box joints with sled Gaffboat Jigs and Fixtures 5 09-30-2014 02:43 PM
In Regard To That Trash Can Lid... Jerry Bowen Tools and Woodworking 25 07-29-2013 01:59 PM
45 degree cuts on box lid Marco The Finishing Touch 5 07-02-2011 12:17 PM
help with loose box lid awoodnut Table-mounted Routing 5 01-03-2010 10:38 PM
