Guide bushings and reducer bushings - Page 2 - Router Forums
 3Likes
post #11 of 14 (permalink) Old 05-24-2015, 06:34 AM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Here is a quick pic of the new shop space. I was looking for a better place to post this here but can't seem to find one.
You all might recognize the Harbor Freight work bench there. I have three of them. One is older and dinged up and will now just serve as counter space on the wall, and to mount my drill press to. The other two are new, placed back to back in the center, and I will shim them to be level with each other for a large work surface. We just built those last night. I was hoping for a better fit but it seems the tops are not going to be exactly even with each other from end to end. I also noticed my old one had a finish on it that seems slicker than these two. They just feel like sanded, unfinished wood. Any suggestions on that? Coat of wax, or even a finish?
For now I will use these to get me started again, but I have dreams of a large super bench, maybe full plywood sheet width, and at least 6 feet long, and dead flat from end to end. I was hoping to use it to help square up cabinet type furnishings as I build them. It might still work, once I get everything shimmed and any high spots dealt with (plane it out, maybe even add a shop made top over them).
Duane Bledsoe is offline
post #12 of 14 (permalink) Old 05-24-2015, 08:13 AM
First Name: Scott.
Have you seen the
Using the right combination of bench dogs (20mm instead of the more usual 3/4") I think they would make a great tool for squaring things up, cutting with a guiderail saw and generally a good idea.
I have no affiliation to them by the way, just spotted something about them on the internet.
PhilBa likes this.
demographic is offline
post #13 of 14 (permalink) Old 05-24-2015, 10:13 AM
Contributor of the Month
Default Router Bushings
Anybody buy bushings from Infinity? I'm a fan of Infinity and have bought most of my bits and blades from them.
JIMMIEM is offline
post #14 of 14 (permalink) Old 05-24-2015, 10:40 AM
Jim, Infinity has long been a friend of the forums. They have sponsored contests and provided door prizes for some of our activities. Anything I have seen from them has been very good quality. I really like their scuff balls.
That said I still recommend the guide bushings from Woodcraft or Lee Valley.
Decent collet reducer bushings? PhilBa General Routing 11 04-29-2015 12:52 AM
