Advice for half lap joints by total newbie..... - Router Forums
 21Likes
post #1 of 39 (permalink) Old 05-18-2015, 04:35 PM Thread Starter
Default Advice for half lap joints by total newbie.....
I am a newbie here and using a router, I need to make some half lap joints in wood that is 75mm square.
I have a 1/4 inch router (cheapie but new), but so far no blades ( it shows how much of a newbie I am as I had expected them to be inside.....)
I believe from reading that a straight router is the correct blade to buy (the wood is pine), and that I should make several cuts rather than trying to make a deep one.....
BUT if anyone can guide me to where I can find more details or even a video I would be VERY grateful, as I am in France I cannot nip down to the local store and ask as they all talk funny and when it gets technical I look like Dory from "Finding Nemo" so please go gently with me.....
thanks in anticipation,
Dave
Penquin is offline
post #2 of 39 (permalink) Old 05-18-2015, 04:39 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum.
Penquin likes this.
Thank You John
Semipro is offline
post #3 of 39 (permalink) Old 05-18-2015, 04:47 PM
Hi, Dave; welcome!
If you'd like to fill out your profile it'd help other members understand what you have to work with...ie a router table or not.
Taking you at your word about being a TOTAL newbie, and that's not a problem here, I'd strongly suggest watching a few YouTube type vids, get a good router how-to book, and if possible take a course...I can see where that might be a problem language wise. Be very cautious at this point; routers bite back!
Do you have Amazon in France?
Router Magic: Jigs, Fixtures, and Tricks to Unleash Your Router's Full Potential: Bill Hylton: 9780762101856: Amazon.com: Books
ksidwy and Penquin like this.
DaninVan is offline
post #4 of 39 (permalink) Old 05-18-2015, 05:31 PM
what size half laps sometimes aka ship laps are you trying to make???
FWIW... what you call blades are actually called bits...
Name:	ROUTER FEED DIRECTION 1.jpg
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 203 views)
File Type: pdf Care and Sharpening of Router Bits.pdf (123.5 KB, 175 views)
Penquin likes this.
post #5 of 39 (permalink) Old 05-18-2015, 05:51 PM
old55's Avatar
First Name: Ross
Welcome to the forum Dave.
Penquin likes this.
Ross,
old55 is offline
post #6 of 39 (permalink) Old 05-18-2015, 07:08 PM
Welcome Dave. How many sides to be machined? If it's two opposing sides I would cut the laps on a long board and then cut them to size. That you can do with the router held in your hands. If you are doing 4 sides then you really need to do that on a router table and make a push block to hold the pieces against the fence and push them past the bit. Otherwise your fingers and hands will be way too close to the bit.
Penquin likes this.
post #7 of 39 (permalink) Old 05-18-2015, 07:24 PM
MT Stringer's Avatar
I don't know what 75mm is so I will just ask...are the joints at the end or in the inner area?
Will you be cutting more than one in the same spot of the same size?
The reason I ask is a template might work well for you. The router can follow the template and give you consistent cuts. It will be up to you to make some test cuts until you get both of the joints exactly half of the cut. Then they should fit together smoothly.
It is always best to practice on some scrap material of similar size and thickness.
Is this what you are asking to do? See pic attached.
The pieces are 75mm square x 25mm thick.
Make both cuts, then flip one of the workpieces and they should fit perfectly forming a half lap joint.
Name:	Half Lap Joints 1.jpg
MT Stringer is offline
post #8 of 39 (permalink) Old 05-18-2015, 07:57 PM
some variations of a lapped joinery...
Name:	ship lap joint.gif
Penquin likes this.
post #9 of 39 (permalink) Old 05-18-2015, 08:21 PM
Need more info. I finally figured out 75mm is 3 inches square. That would be difficult to route hand held. Could prove difficult even with a template.
Penquin likes this.
post #10 of 39 (permalink) Old 05-18-2015, 08:36 PM
double stick them down and route away...
since we don't know the size of the cut it just may be nothing more than a rabbet cut w/ a rabbeting bit......
Penquin likes this.
Routing box joints advice required. JJC General Routing 13 11-11-2013 02:59 PM
Need help with cutting large lap joints jnbrown General Routing 8 08-28-2013 09:06 AM
router bit recommendations for lap joints joepep Router Bits - Types and Usage 7 04-11-2011 07:43 PM
Newbie needs advice enggass General Routing 4 07-05-2010 11:08 PM
