Router direction - Router Forums
 8Likes
post #1 of 13 (permalink) Old 05-19-2015, 07:52 AM Thread Starter
First Name: Katie
Default Router direction
I liked this article on how to figure router direction for various situations. It was simple and clear. Thought others might like it too.
With a Router, You Need Direction
ksidwy likes this.
Goblu is offline
post #2 of 13 (permalink) Old 05-19-2015, 10:43 PM
Katie, another easy to remember trick is to use your right hand. Make a fist, extend your first finger and point your thumb to the left. Put your thumb against the edge you are guiding off of and your first finger shows you the direction of travel.
post #3 of 13 (permalink) Old 05-20-2015, 07:22 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Far too clever Mike. N
neville9999 is offline
post #4 of 13 (permalink) Old 05-20-2015, 08:36 AM
chessnut2's Avatar
Thanks, Katie.
chessnut2 is offline
post #5 of 13 (permalink) Old 05-20-2015, 09:22 AM
Great tip, I can't loose like my printed sheet
dmfotoman is offline
post #6 of 13 (permalink) Old 05-20-2015, 10:43 AM
TWheels's Avatar
This thread should be made "sticky"? Everyone new to routers sooner or later has this question, and Mike's explanation and diagram is as clear as it could possibly be.
My first router, which is now in a landfill, came with a manual that extolled the virtues of climb cutting. Fortunately I had been watching the Router Workshop and believed the now disappeared Bob and Rick over the clearly translated from some Eastern language manual. Somewhere in a thread couple years old it opens with an image of the consequences a nonthinking climb cut on a work piece. I added an image of the consequences of a nonthinking climb cut on my finger! (I was fortunate that it was only a mass of scar tissue that altered the fingerprint and a slightly stiff but otherwise intact finger.)
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 13 (permalink) Old 05-20-2015, 11:04 AM
The rule I go by is to feed towards the flat side of the cutter. No matter what situation you are in or what orientation the router is in this method works. Unlike other methods which require you to think about it with this method you can look at it and see which way is the right way.
post #8 of 13 (permalink) Old 05-20-2015, 01:36 PM
The intervals between routing tasks is just long enough to forget the rule(s). Stick put up a guide that I think I'd better print and put on a wall. I am also wondering what Chuck means by the flat side of the cutter? Wish I could get retired so i could do more woodworking.
post #9 of 13 (permalink) Old 05-20-2015, 01:45 PM
The carbide welded on has a flat face with bevel on the backside. The backside is the side welded to the body. The flat or face side has to be the side facing into the cut. The feed direction is always towards that face. The other direction, facing the beveled edge, is a climb cut. That's why I say that a you have to do is look at it. If the edge being cut is facing the flat you are going the right direction.
post #10 of 13 (permalink) Old 05-23-2015, 09:32 PM Thread Starter
First Name: Katie
Thanks, Mike. I liked the diagram. I'll try that, too. Does this work if you are routing in a circular pattern? I just couldn't figure that out. Also, inside or outside a circle? I tried to route some circles and got confused. Next time I do some routing, I'll try this and also look so see about the flat side of the router.
Goblu is offline
router direction CANMIL General Routing 7 08-09-2012 10:35 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
