Baskets - Router Forums
 18Likes
post #1 of 17 (permalink) Old 05-21-2015, 05:24 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Default Baskets
A friend asked me to make her two Easter baskets for next Easter. Attached is a photo of the one she had - made of pine with dark stain. She said I didn't have to copy it. I have made a dozen or so out of cherry, tiger maple (I put cherry bottom and handles), walnut and spalted maple (again I put cherry bottom and handles). So far the customers like them. The spalted maple were pieces of firewood that I got about 15 months ago. I sliced them on the bandsaw and dried them. At that time the moisture content was 15%. I put 5-coats of General Finish Arm-R-Seal finish then wax the baskets. Malcolm / Kentucky USA
Mike, me5269, billyjim and 12 others like this.
kywoodchopper is offline
post #2 of 17 (permalink) Old 05-21-2015, 05:36 AM
nicely done...
post #3 of 17 (permalink) Old 05-21-2015, 07:34 AM
First Name: Dennis
Very nice-gorgeous walnut. How do you bend the handles, steam or laminate?
Dennis
routergieck is offline
post #4 of 17 (permalink) Old 05-21-2015, 08:00 AM
I love the grain in the 2 baskets. Absolutely spectacular. I also really like the splined corners. Nice work.
ksidwy and Herb Stoops like this.
post #5 of 17 (permalink) Old 05-21-2015, 08:22 AM
RainMan 2.0's Avatar
Wow!
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 17 (permalink) Old 05-21-2015, 08:27 AM
Larry Crouch's Avatar
Great work KY man. What a great finish on a basket also. I love the corner details that you added. Larry
Larry Crouch is offline
post #7 of 17 (permalink) Old 05-21-2015, 11:29 AM
bryansong's Avatar
First Name: bryan
Very nice.
bryansong is online now
post #8 of 17 (permalink) Old 05-22-2015, 05:36 AM
First Name: Larry
Very nice as usual Kt woodchopper
Knot working is offline
post #9 of 17 (permalink) Old 05-22-2015, 06:05 AM Thread Starter
First Name: malcolm
To bend the handles I plane knot free, fairly straight grain wood to 1/8" thick. Then sand it and cut to size. I have a 1 1/2" PVC pipe with a cap on the bottom that I stand in a trash can. I drop several handles into this and pour boiling water into the pipe and place a shot glass over the top to keep the heat in. After 45 minutes I pour the water back into the pot and bring it back to a boil. I do this about 3-times. I then remove one at a time and bend the wood around a form that I made. I clap the piece in for about 12-hours. I remove and attach them to two upright pieces of wood that are the correct distance. This keeps the handles in the same shape and allows them to continue drying. After a couple days I remove them from that setup and just lay them in front of a fan for several days to continue drying. Then sand and start applying finish. I hope this explanation helps. Malcolm / Kentucky USA.
post #10 of 17 (permalink) Old 05-22-2015, 06:57 AM
chessnut2's Avatar
that is a nice explanation, Malcolm. I haven't tried bending yet, but the pieces you did are very similar to what I'll be using in a project I have in mind. I never would have thought of the boiling water in a pipe. Of course, using the shot glass to cover the end will force me to "sip" straight out of the bottle. Thanks. Jim
billyjim likes this.
chessnut2 is offline
Uses for Elm wood? TangoDown3727 Wood Species 27 07-29-2014 08:11 PM
