Router Forums (https://www.routerforums.com/forum.php)
-   General Routing (https://www.routerforums.com/general-routing/)
-   -   rail and style bits (https://www.routerforums.com/general-routing/678-rail-style-bits.html)
dfritz 01-16-2005 11:31 PM
rail and style bits
I am interested in finding rail and style router bits with 1/4 inch shanks. Does anyone know where I might be able to find some? So far all I can find are 1/2 inch shanks. Thanks.
Woodnut65 01-17-2005 07:20 AM
Hi, dfritz:
You may not be able to find the style and rail bits or sets of bits in 1/4" shanks.
The cut for both styles and rails is a heavy cut, and a 1/4" shaft might snap under load. If the router won't take 1/2" bits, I would suggest that you get a bigger router,
and a set of 1/2" bits. The raised panel bits, if you are going to make raised panels,
are 1/2" shafts and they would be dangerous, in 1/4" size
hope this helps, Woodnut65
kp91 01-17-2005 07:59 AM
woodline.com has a couple of sets. I use there 1/2 in shank cabinet maker set, and have had nothing but great results with it.
I also would throw my support behind half inch shanks, that is all I buy. You could use a 1/4 in shank and nibble away at the cut safely though.
I also recommend a 2 bit set or a fixed 2 in 1 cutter. I don't like the sets where you have to take the cutter apart and re-stack it to make the opposing cuts.
Just my 2 cents,
waynoe 01-18-2005 02:51 PM
Don't waist your time. I did have a set with 1\4 inch shanks, I believe it was craftsman. I got so frustrated with them I threw them away. I agee with woodnut, if you can, get a bigger router.
The big bits are just too much for the smaller routers to handle.
That's my opinion.
For what it's worth
Waynoe
muddflap 01-26-2005 12:48 PM
router bits
undefined
you can find 1/4 in. bits at www.mlcswoodworking.com and they have free shipping.
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
