rail and style bits - Router Forums
post #1 of 5 (permalink) Old 01-16-2005, 11:31 PM Thread Starter
Question rail and style bits
I am interested in finding rail and style router bits with 1/4 inch shanks. Does anyone know where I might be able to find some? So far all I can find are 1/2 inch shanks. Thanks.
dfritz is offline
post #2 of 5 (permalink) Old 01-17-2005, 07:20 AM
First Name: Richard
Hi, dfritz:
You may not be able to find the style and rail bits or sets of bits in 1/4" shanks.
The cut for both styles and rails is a heavy cut, and a 1/4" shaft might snap under load. If the router won't take 1/2" bits, I would suggest that you get a bigger router,
and a set of 1/2" bits. The raised panel bits, if you are going to make raised panels,
are 1/2" shafts and they would be dangerous, in 1/4" size
hope this helps, Woodnut65
Woodnut65 is offline
post #3 of 5 (permalink) Old 01-17-2005, 07:59 AM
kp91's Avatar
First Name: Doug
woodline.com has a couple of sets. I use there 1/2 in shank cabinet maker set, and have had nothing but great results with it.
I also would throw my support behind half inch shanks, that is all I buy. You could use a 1/4 in shank and nibble away at the cut safely though.
I also recommend a 2 bit set or a fixed 2 in 1 cutter. I don't like the sets where you have to take the cutter apart and re-stack it to make the opposing cuts.
Just my 2 cents,
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 5 (permalink) Old 01-18-2005, 02:51 PM
First Name: Wayne
Don't waist your time. I did have a set with 1\4 inch shanks, I believe it was craftsman. I got so frustrated with them I threw them away. I agee with woodnut, if you can, get a bigger router.
The big bits are just too much for the smaller routers to handle.
That's my opinion.
For what it's worth
Waynoe
waynoe is offline
post #5 of 5 (permalink) Old 01-26-2005, 12:48 PM
Default router bits
undefined
you can find 1/4 in. bits at www.mlcswoodworking.com and they have free shipping.
muddflap is offline
Raise panel bits, router power davewest Router Bits - Types and Usage 3 02-23-2008 12:36 AM
router bits and wood Doyle Router Bits - Types and Usage 22 06-23-2007 08:34 AM
Shaker style doors lablover Router Bits - Types and Usage 7 05-21-2007 07:02 PM
custom router bits manufacture eloid Router Bits - Types and Usage 9 03-26-2007 10:26 PM
Raised Panel Router Bits Dan Butler Tools and Woodworking 3 11-20-2004 12:30 PM
