Bosch 1617 Accessories - Router Forums
 10Likes
post #1 of 16 (permalink) Old 06-04-2015, 12:25 PM Thread Starter
LBussy's Avatar
First Name: Lee
Default Bosch 1617 Accessories
Originally Posted by Mike View Post
You will want the following accessories to make best use of your router. The RA1151 centering cone; The RA1126 quick change adapter and the RA1100 guide bushing adapter.!
Mike recommended these in another thread. I'm trying to understand what they are. He mentioned using PC guides but I have never routed with guides.
So ... is the RA1126 Quick Change Template Guide Adapter something that allows quick change (looks like a twist lock) of Bosch guides?
And then is the RA1100 Threaded Router Template Guide Adapter an adapter that goes into the quick change, to allow use of more "standard" guides?
Anyone standing by their router with a cell phone want to snap a pic?
MT Stringer likes this.
Lee
Kansas City, MO
LBussy is offline
post #2 of 16 (permalink) Old 06-04-2015, 12:35 PM
MT Stringer's Avatar
Lucky you! It just so happens I have a few I took last year.
You need the adapter, then add the template bushing (guide) to it. The Porter Cable style bushings come threaded so they can be used also. The guide bushings shown are the Bosch metaal variety.
Hope this helps.
Name:	2014-09-18 15.14.13.jpg
Name:	2014-09-18 15.14.20.jpg
Name:	2014-09-18 15.17.48.jpg
Name:	2014-09-18 15.18.37.jpg
Name:	2014-09-18 15.19.13.jpg
Name:	2014-09-19 13.12.14.jpg
LBussy likes this.
MT Stringer is online now
post #3 of 16 (permalink) Old 06-04-2015, 12:37 PM
@LBussy ...
So ... is the RA1126 Quick Change Template Guide Adapter something that allows quick change (looks like a twist lock) of Bosch guides? Yes...
And then is the RA1100 Threaded Router Template Guide Adapter an adapter that goes into the quick change, to allow use of more "standard" guides? Yes...
LBussy likes this.
post #4 of 16 (permalink) Old 06-04-2015, 01:12 PM
Sigh. Another sticky tutorial that is now hard to find.
MT Stringer and ksidwy like this.
post #5 of 16 (permalink) Old 06-04-2015, 01:13 PM Thread Starter
LBussy's Avatar
First Name: Lee
You know ... whatever you want, it IS on the Internet.
I think I know the answer to this but ... with these I will be able to use PC and Bosch bushings, right?
Lee
Kansas City, MO
LBussy is offline
post #6 of 16 (permalink) Old 06-04-2015, 01:14 PM Thread Starter
LBussy's Avatar
First Name: Lee
It keeps us talking Mike. Otherwise EVERYTHING would be on a sticky.
(finding the bright side of life ... )
Mike likes this.
Lee
Kansas City, MO
LBussy is offline
post #7 of 16 (permalink) Old 06-04-2015, 01:24 PM
Yes Lee, the quick change adapter was made for the Bosch steel guide bushings(best for rough construction) and later the adapter was added to allow the use of PC style guide bushings. Brass bushings are the best choice since they do not loosen like the steel PC style ones do.
Shown is the RA1125 set.
LBussy likes this.
post #8 of 16 (permalink) Old 06-04-2015, 01:54 PM
correct...
LBussy likes this.
post #9 of 16 (permalink) Old 06-04-2015, 01:55 PM Thread Starter
LBussy's Avatar
First Name: Lee
Thank you Mike and Stick!
Lee
Kansas City, MO
LBussy is offline
post #10 of 16 (permalink) Old 06-04-2015, 02:47 PM
boogalee's Avatar
First Name: Al
Guide bushing sticky
Mike likes this.
Al B
boogalee is offline
Bosch 1617 collet will not tighten bit Gorm New Member Introductions 29 01-09-2017 02:49 PM
Template Guide for Bosch 1617 hankh Portable Routing 13 11-17-2014 08:59 AM
table/adjustment questions for Bosch 1617 and MR 23 enthusiasts achoox4 Table-mounted Routing 5 06-20-2014 03:38 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch EVS 1617 Adaptor to use PC accessories? kessler craftsman Guide Bushings and Templates 8 05-11-2011 09:35 PM
