DW625 Collets tight - Router Forums
 6Likes
post #1 of 14 (permalink) Old 06-20-2015, 10:33 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Exclamation DW625 Collets tight
Is this normal for a new DW625? I tried toremove the 1/2" collet to install the 1/4" and is was a real nightmare trying to pull the old one out. Once I had finished with the 1/4" I wanted to change back again to the 1/2" and guess what..... it was a real pain getting the 1/4" out.
Is there some trick I'm missing or is it designed for super strong men (or weirdly string women) to change?
Should I make a jig (hole in a chunk of 2x4) and use a dowel to knowck it out?
Any help gratefully received.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #2 of 14 (permalink) Old 06-20-2015, 12:13 PM Thread Starter
vindaloo's Avatar
First Name: Angie
Cancel my request for help. I've bought a couple of new collet nuts so I can just change the whole thing. Less time wasting and hastle.
vindaloo is offline
post #3 of 14 (permalink) Old 06-20-2015, 12:20 PM
are you saying you are nuts and there is no help for ya...
post #4 of 14 (permalink) Old 06-20-2015, 12:37 PM
SO if I understand correctly, you now have a collet nut with a 1/2" collet in it and one with a 1/4" collet in it? That's a smart way to go.
Herb Stoops is offline
post #5 of 14 (permalink) Old 06-20-2015, 03:52 PM Thread Starter
vindaloo's Avatar
First Name: Angie
@stick
I thought that was a pre-requisite of being a member of this forum
I have an 8mm too Herb, so I bought 2 nuts, plus the one I already have that has the 1/2" collet. Apparently this is not the first collet that won't come out of the nut, someone on another forum had the same problem. They bought another nut for another reason (they stripped the threads, heaven knows how) and found the collets easily changeable, they put it down to a machining defect. Still, will be quicker to just swap out the whole thing as the nut has to come off to change the collet anyway.
vindaloo is offline
post #6 of 14 (permalink) Old 06-20-2015, 04:14 PM
Are the new nuts after market, or from Dewalt?
post #7 of 14 (permalink) Old 06-20-2015, 04:25 PM Thread Starter
vindaloo's Avatar
First Name: Angie
They are stated as being 'genuine' so I'm hoping they fit. If not, back they go
vindaloo is offline
post #8 of 14 (permalink) Old 06-21-2015, 08:37 AM
katabrontes's Avatar
Mine was exactly the same. De Walt UK were most unhelpful and said it was normal to have to use personal to pull the collet out of the nut. Hard to do without damaging the collet. Spare nut is the best idea but they charge far too much for it. My other router came with both collet in their own nuts.
katabrontes is offline
post #9 of 14 (permalink) Old 06-21-2015, 11:24 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Mike, I got the two nuts for £5.20 each posted. Now I'm worried they aren't the right ones!
vindaloo is offline
post #10 of 14 (permalink) Old 06-22-2015, 03:10 AM
Not bad if they fit. Best I can find is £7.99 + post from Part Shpop Direct UK. Axminster now only sells the nut complete with an 8mm collet for about £15 + post. I can't find the nut alone on their website now. In the end I have just used a 1/2" to 1/4" sleeve which was about £3 delivered with some other stuff. As I rarely use 1/4" bits it will do and runs smoothly.
Using DW625 In New Table ghayes Table-mounted Routing 2 11-21-2010 08:43 AM
Hitachi M12VC Collets amishx64 General Routing 11 06-22-2010 05:56 PM
Triton/Hitachi collets Rayinthe UK General Routing 1 09-12-2006 04:35 AM
