Cutting a Serving Tray Bottom - Router Forums
 22Likes
post #1 of 25 (permalink) Old 06-20-2015, 11:29 AM Thread Starter
berry's Avatar
First Name: Berry
Default Cutting a Serving Tray Bottom
Hello,
I'm making a serving tray. I'm to the point where I need to cut the bottom. As you can see I've routed a rabbit to hold the bottom and while I can mark and cut with a jig saw I thought there must be a cleaner/sharper method using a router and pattern bit. But I don't know what it is or how to make the cut.
I have two routers a Bosch 1617 and a DeWalt trim router. Both fixed and plunge bases for each and some trim bits.
One pic shows the tray up-side-down and the other in the correct orientation. The bottom is cherry pw, mdf core.
Thanks for looking on this busy weekend. I hope one of you clever folks can point me down the path.
Happy Father's Day Berry in St. Paul
Name:	JZ 010259.jpg
May the grain be ever in your favor.
berry is offline
post #2 of 25 (permalink) Old 06-20-2015, 11:33 AM
You might make a template from your tray that is cut out larger than the tray bottom and use a bushing and template bit to cut it out.
berry likes this.
Herb Stoops is offline
post #3 of 25 (permalink) Old 06-20-2015, 12:02 PM
for a flush bottom...
make the 1st cut using the outside of the tray's frame as a guide w/ your panel bit...
cut your base and a pattern at the this time...
sandwich the two together w/ DS tape...
now using a rabbiting bit w/ the bearing adjusted for depth of cut you need to cut the bottom down to size follow the pattern w/ the bearing and cut the bottom piece down to size...
Rabbet Combo Kit, 1/2" Shank, 1" Cutter Height Router Bit-Carbide Router Bits | Router Bit Sets | Shaper Cutters | Saw Blades | Planer Knives | Jointer Knives | Infinity Cutting Tools
berry, Gaffboat, MYB and 1 others like this.
post #4 of 25 (permalink) Old 06-20-2015, 04:36 PM Thread Starter
berry's Avatar
First Name: Berry
That worked great Stick, it's all done. I owe you a beer!
berry is offline
post #5 of 25 (permalink) Old 06-20-2015, 06:33 PM
Ole Stick knows his stuff, even if he is a stubborn old fart.
HJ
RainMan 2.0 likes this.
honesttjohn is offline
post #6 of 25 (permalink) Old 06-20-2015, 08:48 PM
Good deal Berry. I hope you took photos of the process to share with members learning about using templates and guide bushings.
post #7 of 25 (permalink) Old 06-20-2015, 11:08 PM
HJ
were do you get old from???...
vindaloo likes this.
post #8 of 25 (permalink) Old 06-20-2015, 11:25 PM
OH,by the way, Berry, I like your tray design. Very nice the way you made the corner joints and the curved corners. Looks like you already used the rebate bit to cut the rebate for the bottom in the rails. Very nice job,show us what it looks like when it is done ,like Mike suggests.
post #9 of 25 (permalink) Old 06-21-2015, 12:01 AM
cut two bottoms using the outside of the tray's frame as a guide w/ your panel bit...
one is to be used for/as a pattern and the other is the actual bottom....
now using a rabbiting bit w/ the guide bearing's diameter adjusted for depth of cut follow the pattern and cut the bottom piece down to size...
http://www.infinitytools.com/Rabbet-...ctinfo/00-556/
note...
I had to rewrite this so I understood it....
jw2170 likes this.
post #10 of 25 (permalink) Old 06-21-2015, 12:10 AM
Stick, new members really benefit from photos of the process. A picture is worth a thousand words.
ksidwy, RainMan 2.0 and Geevesmac like this.
Experience with my first cutting board Barry747 Tools and Woodworking 8 05-04-2015 04:25 PM
Sanding flat with a belt sander....tricky?! matt1710 Tools and Woodworking 20 04-22-2015 12:53 PM
kitchen cabinet boxes - sides and bottom reikimaster Tools and Woodworking 12 02-12-2013 02:14 PM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
