Straight bit vs. spiral bit - Router Forums
 5Likes
post #1 of 15 (permalink) Old 06-26-2015, 06:49 AM Thread Starter
JimofSC's Avatar
Default Straight bit vs. spiral bit
I am just getting into using the router and using it more all the time. I do not own any spiral bits just some straight ones. What is the purpose of a spiral bit? Any advantages and/or disadvantages of the two?
Jim
JimofSC is offline
post #2 of 15 (permalink) Old 06-26-2015, 07:11 AM
Jim
Spiral Bits
ADVANTAGES
• Very clean cut
• More cutter in wood means less vibration
• Better plunge-cutting
• Less wear and tear on router
• Direct chips up or down
DISADVANTAGES
• Limited lengths and diameters
• Can be somewhat risky to use Straight Bits
Straight Bits
ADVANTAGES
• Wide variety of lengths and diameters
•Guide bearings on tip or shank mean better template routing
•Less expensive
•Greater ability to resharpen
DISADVANTAGE
• Plunge-cutting requires more effort and skill -
http://www.routerforums.com/router-b...ut-spiral.html
http://www.mlcswoodworking.com/shops...TM25spiral.pdf
Semipro, jcayer and mbar57 like this.
post #3 of 15 (permalink) Old 06-26-2015, 08:29 AM
First Name: Brad
Down cut spiral cut bits are great for laminates. Use a down cut and it will not chip out like a straight bit would.
Upcuts are great to remove material from the slot quickly so you can see what you are doing. Not as useful, but it can be for some.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #4 of 15 (permalink) Old 06-26-2015, 10:28 AM
PhilBa's Avatar
First Name: phil
Sprirals are the prima donnas of the router bit world - they give great performance but are expensive and temperamental. I love upcut spirals for plunging because they clear out the cut and leave a very clean finish. Down cuts leave a very clean edge. Compression spirals are great for through slots where clean edges are important. Unfortunately, they are pricey - solid carbide which also means they are brittle and easy to break. I broke one the other day when I pushed too hard on it. c'est la vie...
By the way, if a clean edge cut is super important, you can get shear bits that do about the same.
PhilBa is offline
post #5 of 15 (permalink) Old 06-26-2015, 10:50 AM
Jim, since you are just starting out you should check out these threads. I think they will be a great help to you.
http://www.routerforums.com/router-b...tml#post505441
post #6 of 15 (permalink) Old 06-27-2015, 06:25 AM Thread Starter
JimofSC's Avatar
Thanks All. Very helpful information!!
Jim
timbertailor and mbar57 like this.
JimofSC is offline
post #7 of 15 (permalink) Old 06-27-2015, 03:46 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
A perfect answer, Herb, the things that does not get said is this, Straight bits that are kept sharp cut perfectly fine, keep you cutters sharp and they work properly, spiral bits are normally solid tungsten so they stay sharp longer, still when they do go off, and they do, then they also need to be made sharp again. N
neville9999 is online now
post #8 of 15 (permalink) Old 06-27-2015, 05:50 PM
First Name: Clay
I never realize how good they were still I bought one to trim my solid surface tops with. I will not be using regular straight cutters anymore. It just cuts so much smoother I used to get a little chatter with regular bits the solid carbide spiral bit eliminated that.
Not sure how many more feet it will be able to cut, but I am betting it will be a lot.
fire65 is offline
post #9 of 15 (permalink) Old 06-28-2015, 03:44 PM
Clay, all bits have their uses. The low cost of straight bits allows you to buy a larger selection of sizes and they are easy to touch up with a diamond credit card sharpener. A couple light passes over the diamond and the edge is restored.
Name:	Diamond sharpening.JPG
post #10 of 15 (permalink) Old 06-28-2015, 07:53 PM
First Name: Clay
I realize all bits have their uses. I have many bits, this was about the difference in straight bits and spiral bits.
Take time to correct what is needed, this thread was about the difference, nothing to do with sharpening, which I know how to do.
I use them both, do you? If so, what is the difference and is it worth the cost, which is what this thread is about.
fire65 is offline
Straight bit to "flush trim" WoodCrusher Router Bits - Types and Usage 4 04-19-2015 08:31 AM
straight bit rabbeting question from a nubee. xoxo-aj Router Bits - Types and Usage 13 12-30-2011 04:06 AM
Ruined my 1/2" spiral bit. RJM60 Guide Bushings and Templates 2 09-13-2010 05:51 PM
Spiral Bit Question cabinetman Router Bits - Types and Usage 12 07-24-2010 02:30 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
