Removing Router Base - Router Forums
 16Likes
post #1 of 28 (permalink) Old 06-26-2015, 06:28 PM Thread Starter
Default Removing Router Base
Hey guys, i have a Black and Decker RP200 router. I want to buy a circle cutting jig but for the life of me, i can't figure out how to unscrew the base. It is like a star screw, any help would be much appreciated.
xman111 is offline
post #2 of 28 (permalink) Old 06-26-2015, 06:40 PM
try a torx #15 or 20...
http://www.walmart.com/c/kp/torx-screwdriver-set
Herb Stoops and mbar57 like this.
post #3 of 28 (permalink) Old 06-26-2015, 06:51 PM Thread Starter
thanks my friend, it was a #20 Torx.. Don't know what I was thinking.. thanks again, saved me a bunch of frustration!!!
xman111 is offline
post #4 of 28 (permalink) Old 06-26-2015, 07:54 PM
PhilBa's Avatar
First Name: phil
Given the multitude of driver types, it's a good idea to get a "security driver bit set". Has lots of different driver types. For a few bucks, you will never be shut out.
MT Stringer and mbar57 like this.
PhilBa is offline
post #5 of 28 (permalink) Old 06-26-2015, 10:33 PM
I have done that, and know What? I still run across situations where I don't have the right bit. I used to have 2 screwdrivers a flat and a phillips, now I have a Drawer full of different styles, and they keep coming out with more.
I have to laugh, the selfdriving outdoors screws come with a bit in the package, and then you grab a next sized longer one and WALLA!!!, you have to change bits to drive that one screw.
Herb Stoops is offline
post #6 of 28 (permalink) Old 06-26-2015, 10:40 PM
Gaffboat's Avatar
First Name: Oliver
It gets frustrating sometimes, doesn't it. I recently bought some new screws and had to try three square drive bits before I found the right one.
jw2170 and Herb Stoops like this.
Gaffboat is offline
post #7 of 28 (permalink) Old 06-26-2015, 11:52 PM Thread Starter
thank. again guys. now to decide if I buy the circle jig or try to make one
xman111 is offline
post #8 of 28 (permalink) Old 06-27-2015, 12:01 AM
PhilBa's Avatar
First Name: phil
well to tell the truth, I have been shut out because a cheapo HF bit didn't last that long. Nothing worse than a round shoulder square drive bit when your trying to drive that last screw. So I bought a set of 5 square drive bits and solved that problem. Next box of screws I bought? Spax with their torx drive. I've been trying to stick to square drive, though.
Herb Stoops likes this.
PhilBa is offline
post #9 of 28 (permalink) Old 06-27-2015, 01:24 AM
Yeah, thats the one Spax! It is a great bit ,but it really holds but they have different sizes. Not many other screws use the same system.
post #10 of 28 (permalink) Old 06-27-2015, 01:38 AM
Just switch to the impact driver Robertson bits; Man, what an improvement!
DaninVan is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
