Using a router to make chair backs - Router Forums
post #1 of 10 (permalink) Old 01-21-2008, 09:49 PM Thread Starter
Default Using a router to make chair backs
has anyone had any experience routing dinning room chair backs that are made from furniture grade plywood , out side edges curves a pattern inside with about 10 differ to make these???
I tried this on one and the bit dulled quickly and started to burn the wood. Router bit was not of good quality but is this the way to make the chair back and if so what brand and kind of bit should I use???
robrouter (a newbe to routing)
robrouter is offline
post #2 of 10 (permalink) Old 01-22-2008, 01:53 AM
Rob, plywood is seldom used for dining room furniture, at least for chair backs. Could you please post a photo of the type of chair you want to build and then we can tell you the process. If this is for a normal chair back and you wanted it laminated for strength you would build a form and then clamp thin layers of wood and glue to the form to create the shape. While this seems like plywood it isn't by a long shot.
post #3 of 10 (permalink) Old 01-22-2008, 07:28 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Robrouter, if you can afford to be patient, the forums routing guru, Template Tom O'Donnell is in the process of making dining room chairs with routed curved backs. I was privy to the routing procedure a few days ago and as soon as Tom resolves his computer in-compatibility problem with the forum (he can't download photographs) he will be showing how it was done.
Harry
harrysin is offline
post #4 of 10 (permalink) Old 01-22-2008, 10:57 AM
curiousgeorge's Avatar
First Name: George
Welcome to the forums, Robrouter. As Harry has stated, if you can wait, I guarantee it will be worth it. Template Tom can do some awsome things with a router.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #5 of 10 (permalink) Old 01-22-2008, 01:01 PM
Hi robrouter
Using plywood for chairs ,,, I have seen some great chairs made out of plywood but not the furniture grade type plywood,,,you can get some Baltic Birch plywood that has no volds or to say holes/gaps .. plywood is very strong and stable but you will need to go the extra mile and not use any metal fastners just wood joints...plus it's great to fill the shop up with the smell of cutting plywood in the shop..great wood shop smell
PLYWOOD is hard on router bits,full of resin/glue that's as hard as nails.
SO you will need to buy many bits to get the job done,,,plywood is just like taking thin wood and putting into layers ,very strong...
You can also put on trim edging but the look of plywood is neat some times.
If you go back in time just a bit you will see at one time many chairs used plywood,,,unlike the junk man made wood they now use, the norm was 3/8" and 1/2" thick for the backs..it's hard to break plywood...
good luck with your project Rob
post #6 of 10 (permalink) Old 01-22-2008, 03:21 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Rob. Glad you joined us.
Dave
the "Doctor"
Dr.Zook is offline
post #7 of 10 (permalink) Old 04-28-2010, 09:10 PM
First Name: nathan
Default Dining room chairs
thanx ,
Get yourself stylish dining furniture , dining chairs and dining tables are at great savings online at spacify.
nathan123 is offline
post #8 of 10 (permalink) Old 04-29-2010, 01:22 AM
Dr.Zook's Avatar
Welcome Nathan, to the RouterForums. Thanks for participating in our forums.
Dave
the "Doctor"
Dr.Zook is offline
post #9 of 10 (permalink) Old 04-29-2010, 10:46 AM
First Name: JC
Welcome to the forum!!!
jbcasper4 is offline
post #10 of 10 (permalink) Old 04-29-2010, 10:04 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. We are pleased you have chosen to join with us.
Lamentations 3:22-23
xplorx4 is offline
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
Router story lea6141 General Routing 2 01-28-2008 10:10 PM
Router Table, buy or make? S Bolton Table-mounted Routing 6 08-21-2007 10:35 PM
router table (craftsman) reds_21 General Routing 6 08-08-2005 08:10 AM
