Dados and Bits Question - Router Forums
post #1 of 5 (permalink) Old 01-23-2008, 01:06 PM Thread Starter
Default Dados and Bits Question
My stock is 11/16" thick, if I use a 3/4" bit for the dado will the joinery be too loose?
Ariel is offline
post #2 of 5 (permalink) Old 01-23-2008, 01:40 PM
11/16" is an odd thickness, is this plywood? If so I think you will find that it actually measures 23/32". Various companies make what they call plywood bits which corespond to the actual sizes of plywood: 23/32", 15/32", and 7/32". If you use a different size bit you will have a loose fit and that is bad news. You can always use a smaller bit, make a pass and reposition your guide or fence to complete the size cut you need.
post #3 of 5 (permalink) Old 01-23-2008, 02:05 PM Thread Starter
Yes, it's plywood, it's a special Maple/Birch combo and I've used 3 different measuring devices on it and it comes up 11/16 every time. I always thought it was 3/4 until I measured 9 x to be sure. LOL
If I get a 23/32 bit and it turns out to be a true 11/16, will that still be too loose?
Ariel is offline
post #4 of 5 (permalink) Old 01-23-2008, 02:51 PM
Hi Ariel
If you are sure it's 11/16" just buy a bit that size...
http://woodworkersworld.net/straight_bits.shtml
And yes if you use a 23/32 bit it will be to loose by a 1/32... but sometimes that good,, unless you have a big rubber hammer..
It sound like wood mfg./lumber mills are doing that now to save money in making playwood and MDF...I got some MDF the other day and it was marked 3/4" but it was 23/32 the norm for plywood... and the norm for MDF, if it's marked at 3/4" thick it should be,,,but the new stuff is going the way of the candy bars...same price less product..
post #5 of 5 (permalink) Old 01-23-2008, 09:16 PM Thread Starter
I decided your answers sounded more plausible and ordered the 23/32 bit.
I think I'll be happy with that!
Ariel is offline
Plywood/dado router-bit question Toolfreak General Routing 11 11-17-2009 09:34 AM
Question about test cut graywolf General Routing 1 10-21-2006 10:54 PM
short dado's krimson_cardnal Jigs and Fixtures 16 06-13-2006 01:28 PM
