Question about raised panels - Router Forums
post #1 of 5 (permalink) Old 01-29-2008, 04:39 AM Thread Starter
Default Question about raised panels
Is there a maximum size for panels before you have to start using edge glued panels as opposed to just making it out a leftover piece of wood? Length or width...
tpyke is offline
post #2 of 5 (permalink) Old 01-29-2008, 10:47 AM
curiousgeorge's Avatar
First Name: George
I would suggest no more than about 6" wide boards for panel glue ups. My reasoning for this is that the wider boards tend to warp easier. I am by no means an expert on this but, I did stay at a Holiday Inn last night.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is online now
post #3 of 5 (permalink) Old 01-29-2008, 11:04 AM
Hi tpyke
The tree rings will tell you all you need to know..
You don't want them,,,in the center, it works very well if you use 2" to 2 1/2" wide the norm...just flip them over and glue them up, the wider the stock the bigger the cup..this is true for women also it all falls in to place.. mother nature is just that way...
Some use the 6" rule but if the tree was only 8" to 10" in dia. well you see what I mean.
post #4 of 5 (permalink) Old 01-29-2008, 01:10 PM
Charles M's Avatar
I don't know of any hard and fast rules but I typically make all panels over ~5" wide from glue-ups. The width of the pieces I use is most times the same as the width of the stiles and rails (usually 2-1/4" for cabinet doors) because I rip all components at the same time..
Charles M is offline
post #5 of 5 (permalink) Old 01-29-2008, 01:40 PM
First Name: George
Good tip Charles! Makes sense to me.
George
Fort Worth, Texas
Question on raised panels kylawyer Table-mounted Routing 8 03-24-2011 12:29 PM
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
