Routing large lap joints - lots of them... - Router Forums
 18Likes
post #1 of 31 (permalink) Old 07-26-2015, 04:58 PM Thread Starter
First Name: Jon
Default Routing large lap joints - lots of them...
I am planning a new garden shed.
Part of my design involves quite a lot of cross and end lap joints.
Now I know a lot of people recommend just butt-jointing but it's my project and I'm being stubborn on this one
If it were just a few joints I would do them buy hand - but having totalled up the timbers and intersections I am looking at about 100 joints
To make matters worse, they are big joints - 63mm square and 19mm deep for most of them.
My plan is to clamp multiple timbers together and run the router across them, but with such a large amount of timber to remove and only a cheap router at my disposal, I'm worried it will be too much for it.
I had a thought - If I set my circular saw to a little less than the final depth and make several cuts with it, much like I would when making the kerf's by hand, and then use the router to remove the remainder and set the final depth.
Is this a good strategy do you think?
DaninVan likes this.
Carrot is offline
post #2 of 31 (permalink) Old 07-26-2015, 05:09 PM
have a look see here...
Oliver aka Gaffboat has your method, jig and answer...
http://www.routerforums.com/general-...long-area.html
Carrot and gjackson52 like this.
post #3 of 31 (permalink) Old 07-26-2015, 05:34 PM Thread Starter
First Name: Jon
[can't post the url ]
Excellent - so I wasn't being daft then - that was practically what I was thinking of doing, but those sketchups sure helped visualise it.
Roy Drake likes this.
Carrot is offline
post #4 of 31 (permalink) Old 07-26-2015, 05:44 PM
It's always a good idea to remove as much of the waste with a more efficient tool no matter what the routing operation. If it's a hole or mortice then drill the waste, skil saw in this case where you have a lap, following a pattern then bandsaw or jigsaw, etc. Routers are a finishing tool. They aren't good at removing a lot of wood.
Carrot and RainMan 2.0 like this.
post #5 of 31 (permalink) Old 07-26-2015, 05:46 PM
That's actually a quite helpful comment for us beginners. Thanks.
Carrot likes this.
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #6 of 31 (permalink) Old 07-26-2015, 05:51 PM
Excellent - so I wasn't being daft then - that was practically what I was thinking of doing, but those sketchups sure helped visualize it.
daft is a good thing...
we understand and communicate well in daft here...
Dan3103 likes this.
post #7 of 31 (permalink) Old 07-26-2015, 05:59 PM
TwoSkies57's Avatar
Being multi-lingual certainly has its advantages
Skipper the Penguin
TwoSkies57 is offline
post #8 of 31 (permalink) Old 07-26-2015, 06:02 PM
Originally Posted by TwoSkies57 View Post
Being mufti-lingual certainly has its advantages
being well versed in typonese is a major plus...
post #9 of 31 (permalink) Old 07-26-2015, 06:24 PM Thread Starter
First Name: Jon
I'm multi lingual
I can do British, American and Australian...
As well as endless gibberish!
jw2170 likes this.
Not as green as I am cabbage looking!
Carrot is offline
post #10 of 31 (permalink) Old 07-26-2015, 06:28 PM
Jon, doing multiple timbers at the same time is for sure the way to go!
Gang cutting on jobsites is standard practice, especially for something like you're doing.
I often have to do that on 4 x 4/6x6 posts, where they'll be supporting beams or box joists. Just makes sense; huge time saver, and way easier on your tools.
Here's a discussion on the concept...
contractortalk.com/f14/cutting-rafters-88708/
Carrot likes this.
DaninVan is offline
Best way to set up a jig for LARGE finger/box joints? PhillyGuy Jigs and Fixtures 51 08-12-2015 06:42 PM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
Really Large Finger Joints Scott In Vermont Tools and Woodworking 4 03-31-2011 05:50 AM
Routing large diameter circles phil brough General Routing 3 08-02-2008 11:35 PM
