Directional Bits - Router Forums
post #1 of 9 (permalink) Old 02-11-2008, 11:21 AM Thread Starter
Default Directional Bits
I noticed there's Upcut and Downcut bits, is this as simple as using from Left to Right and Right to Left or is it more complicated than that?
Ariel is offline
post #2 of 9 (permalink) Old 02-11-2008, 12:41 PM
curiousgeorge's Avatar
First Name: George
Ariel, it has nothing to do with right or left. It refers to the cutting direction of the bit itself. For instance, in cutting a mortice in solid wood you would probably want an upcut because it cuts in an upward spiral and draws the chips upward out of the hole. On the other hand, if cutting a dado in plywood you might want a downcut because the downward spiral of the bit will be less likely to splinter the plywood layers. There are other uses, but these are just examples. Hope this helps.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #3 of 9 (permalink) Old 02-11-2008, 04:04 PM Thread Starter
Thanks, that helped a lot and it makes more sense.
Ariel is offline
post #4 of 9 (permalink) Old 02-11-2008, 05:26 PM
GWH
For a clean surface cut you would want a down cut spiral bit. It does not splinter out the surface as the rotation of the bit is in a "downwards" direction. If surface condition is not a concern, you would probably want to choose an upward cutting spiral bit.
GWH is offline
post #5 of 9 (permalink) Old 02-12-2008, 05:36 PM
There is also a compression cutter which is for edge cutting on plywood and veneered materials. This type of cutter squeezes towards the center to prevent tear out top or bottom.
post #6 of 9 (permalink) Old 03-03-2008, 11:28 PM
Yesterday, at Lowes, I saw a left-hand spiral bit and a right-hand bit... how would these correspond to the upcut/downcut bits referred to above?
babzog is offline
post #7 of 9 (permalink) Old 03-04-2008, 08:13 AM
First Name: del
If you aren't doing a lot of cutting they will work that's what they are spiral up and spiral down Do your self a good deed and buy Some good one's The one's at the box store's don't last long I use Amana bits I can get them local And they last a long time And are sharp Their are a few more good mfd. out their They cost more But are worth it del
del schisler
port st. lucie, florida
del schisler is offline
post #8 of 9 (permalink) Old 03-04-2008, 11:47 AM
First Name: George
babzog, I hope I get this right, but if not someone will correct me. The left hand spiral is the upcut and the right hand the down cut.
George
Fort Worth, Texas
post #9 of 9 (permalink) Old 03-04-2008, 11:52 AM
It also can be if you are using the router right side up or upside down in the router table..
Basic Router Bits DONALD Router Bits - Types and Usage 18 01-10-2013 07:50 PM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 04:36 AM
tounge & groove bits kamrx7 General Routing 3 11-21-2006 10:31 AM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 10:35 PM
another sorry question about router bits reds_21 General Routing 7 12-30-2004 05:31 PM
