Planter/Trellis - Router Forums
 20Likes
post #1 of 23 (permalink) Old 08-05-2015, 02:18 AM Thread Starter
old coasty's Avatar
First Name: Bob
Default Planter/Trellis
Every problem has a solution. finding it sometimes takes time. Our problem was the next door neighbors up higher in their back yard, with their seats aimed so they could look down on us, instead of at their back yard, or at their other neighbors on the same level with them.. This was last spring, and we debated the options.
First, tried the plastic planters with cedar trellises I made, but growth rate with flowers was too slow. More debating and searching for solutions.
Then they put up the White Stuff and a toilet bowl planter in the yard.
So the next try was a planter with a trellis, and it worked like a charm. Also we planted Victoria Bushes which will work even better in about 3-4 years.
The planter is a basic cedar box with two 17: square plastic liners one in each side of the box. Cedar 2x4’s, cedar fence slats, and cedar decking was used.
The trellis was made to be taken off if the planter was to be relocated in the future. The 2x4 sides fit over the stiles of the box and 2 stainless lag bolts in each side hold it well.
Slats were made from rough cedar fence slats which determined the height of the grid. Didn’t have a planer, so all were sized on a 4” jointer and ripped to 1 “ wide on the TS.
Finally we get to the router. Made a jig. I’m a firm believer in Mike”s “it doesn’t have to be pretty, it just has to work”. Mine was made from parts from other jigs. It was used to make the pieces for the side rails and stiles to hold the slats in the grid.
I made it based on a box joint jig, but instead of moving the work on the jig, I moved the jig on the work. I routed the first slot with the jig across the stacked pieces that hold the slats in the rails and stiles. The piece on the bottom marked in black is a piece of a slat that was added after the first rout across the stack. From then on, it was put that slat in the last routed slot to do the next one and keep moving on down to the end of the stack.
Obviously the photo ready to route has the clamp upside down, sure couldn't route it like that.
I screwed the two side pieces on the stiles first because there were more of them than the vertical ones, and laid the horizontal slats in place.
Then I screwed the bottom piece in place, inserted the vertical slats in place, and jiggled the top ends to fit in the top piece. Trim pieces were screwed on the rails and stiles to close the open sides of the slats.
All fasteners were stainless steel and thankfully no finish was desired. Hate finish on outside wood, when time takes it’s toll and refinishing comes along. Cedar and Teak age gracefully on their own.
The top of the grid is 82 inches off the deck, and the top of the dirt in the planters is 20 inches off the deck. I only offer those dimensions so you can see how tall 1 red and 1 yellow grape tomato plant can grow. Today they are over a foot taller than the top of the grid and loaded with tomatoes.
Makes a great privacy fence, so mission accomplished.
Jon, this was not considered a square box by SWMBO with the Grid on it.
Name:	1 Original Problem.jpg
Name:	2 Trailer Trash.jpg
Name:	3 Strips Clamped.jpg
Name:	4 Jig Top.jpg
Name:	5 Jig Bottom with Spacer.jpg
Name:	6 Ready to Rout, top clamp was other side down when routing..jpg
Name:	6a End Product of routing.jpg
Name:	7 As Built Front copy.jpg
Name:	8 As Built Back copy.jpg
Name:	9 Corner Detail.jpg
Name:	10 07:18:2015  Tomatoes.jpg
Name:	11 07:18:2015 Back.jpg
Mike, JFPNCM, N'awlins77 and 16 others like this.
old coasty is offline
post #2 of 23 (permalink) Old 08-05-2015, 02:26 AM
man that is nice.... as in really nice...
post #3 of 23 (permalink) Old 08-05-2015, 05:51 AM
Country: South Africa
First Name: Paul
Brilliant job.
You have given me a couple of ideas with that jig of yours.
Cheers Paul
PaulH is offline
post #4 of 23 (permalink) Old 08-05-2015, 07:39 AM
First Name: Gary
Bob, Using the Key on your jig was a real time saver. Great Solution!
gmercer_48083 is online now
post #5 of 23 (permalink) Old 08-05-2015, 08:10 AM
Country: Brazil
First Name: sid
Marvelous job and view Bob! I like it a lot!
Sid
ksidwy is offline
post #6 of 23 (permalink) Old 08-05-2015, 09:03 AM
Country: Mexico
First Name: Joseph Anthony
Thumbs up
Just AMAZING !
RÖENTGEEP is offline
post #7 of 23 (permalink) Old 08-05-2015, 10:31 AM
Nickp's Avatar
First Name: Nick
Wow...another set of ideas...so little time...looks great...
Nick
Nickp is offline
post #8 of 23 (permalink) Old 08-05-2015, 11:12 AM
MT Stringer's Avatar
+1 What he said.
MT Stringer is offline
post #9 of 23 (permalink) Old 08-05-2015, 11:35 AM
Good job,great design and good thinking on the jigs, that is sure a way to save some time. Thanks for posting,
Herb Stoops is online now
post #10 of 23 (permalink) Old 08-05-2015, 11:55 AM
Ghidrah's Avatar
First Name: Ronald
OC Bob,
Once I saw the 1st pic I understood the situ, their little canopy swing points directly at your deck. Is the cardinal flag the right height to block the view while sitting in the comfy shaded chairs?
The planter Trellis is a grand object of art; even without the greenery the lattice blocks pretty much everything down to shadows.
Herb Stoops likes this.
Ghidrah is offline
