First router - Router Forums
post #1 of 6 (permalink) Old 02-18-2008, 10:54 AM Thread Starter
Default First router
Hi all, My wife bought me the skil 1825 as a starter & I am unable to put the 1/4" bits & tighten. It appears to have the 1/2 " collet inside. I read the manual several times to no avail. Thanks for your thoughts!
outbacker is offline
post #2 of 6 (permalink) Old 02-18-2008, 11:16 AM
Hi outbacker
Try this , pull out the user manual out one more time and go to the page(s) for the parts list,,,,,( in the back) go down the list and look for the item called collet or adaptor something like that,,,,go by part by part if you don't find the item in the box take it to the store and tell them you didn't get one and I'm sure they will give you one so you can use 1/4" shank router bits..
It should look something like the one below..
post #3 of 6 (permalink) Old 02-18-2008, 11:49 AM
curiousgeorge's Avatar
First Name: George
outbacker, Welcome to the forums!
Here is the PDF owners manual. Check on page 9 fig. 6 and it shows you should have an adapter sleeve. Also here is the parts list info:
Item #655, Qty. 1, Order #2 610 915 608, Description: ADAPTER
I found this info on skiltools.com.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 6 (permalink) Old 02-18-2008, 03:54 PM Thread Starter
BJ, Thanks for your help, I found that items. I looked at the manual do I push this part into the armature shaft. It doesnt fit ,too tight should it be hammered in? Once again thanks for you help.
post #5 of 6 (permalink) Old 02-18-2008, 04:09 PM
Hi outbacker
You'er Welcome BUT put the hammer back in the tool box..
Take the collet nut off all the way then push it place,,,it's should be tight but not so tight you need a hammer to put it in place...
Tap it with your hand but that's all, so it just slips in..
post #6 of 6 (permalink) Old 02-18-2008, 06:06 PM
Hamlin's Avatar
First Name: Ken
Welcome to the router forums.
Ken
"A VETERAN"
Hamlin is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
