Locking Miter - Router Forums
post #1 of 4 (permalink) Old 02-18-2008, 01:38 PM Thread Starter
First Name: George
Default Locking Miter
I finally got my Katana Locking Miter bit and so far have gone thru about a truck load of scraps. Not really but have gotten the thing to work...I LIKE it.
Question, how do you make a locking miter joint on a picture frame? I just can't seem to get the orientation right on the corners. This is where I produced most of the "lil dinky scraps" (LDS).
Thanks,
George II
George Cole
George II is offline
post #2 of 4 (permalink) Old 02-18-2008, 02:37 PM
Hi George II
The normal Locking Miter bit is to big the norm for picture frames but you can get a baby Locking Miter bit that will do the trick, but it's not made to do that, and it's a hard one to set up right..
I would suggest you use a spline joint on the picture fames...
You can make a quick jig to do just that,, if you want to see one just ask and I will post one..that you can use on the router table...
Here's just one way George
http://www.routerforums.com/jigs-fix...slot-jigs.html
Thanks,
George II
George Cole
post #3 of 4 (permalink) Old 02-18-2008, 08:00 PM Thread Starter
First Name: George
Bob,
I would appreciate the jig as well as the spline joint bit. I am not sure of the what or how to. I am really getting into this router stuff..
Thanks,
George Cle
post #4 of 4 (permalink) Old 02-18-2008, 08:05 PM
Hi George II
Just click on the link in post number #2 (above) and it will take you to the jig..
It's a real easy one to make, plus it works on just about all picture frames,,
or just about any 45 deg. joint..
Just a note****you don't need to use the saw blade if you don't want to ,a slot cutter will do the job just fine... just remove the bearing off the slot cutter bit..
Bob,
Thanks,
George Cle
T-Track vs. Miter Channel Paul3624 Table-mounted Routing 12 05-12-2010 11:25 AM
Locking Miter Bit jnovacek Router Bits - Types and Usage 2 03-07-2008 01:57 PM
Locking mitre joints for picture frames grandsire02 Table-mounted Routing 3 08-10-2007 02:56 AM
Table Saw Miter Guage Fence dunmovn Tools and Woodworking 3 12-11-2006 03:21 PM
miter gauge for table saw, help delroy33 Tools and Woodworking 3 10-27-2004 05:01 PM
