Craftsman Pro router & OP plate - Router Forums
post #1 of 1 (permalink) Old 02-28-2008, 07:16 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Default Craftsman Pro router & OP plate
On Oak Parks site it does NOT list this particular model (model# 130.26620) from craftsman. So, if any have the same as I do and you want to use an OP plate... you need to get Type A and you will use the 3 hole pattern.
Ken
"A VETERAN"
Hamlin is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
router plate for a craftsman 17542 dougj71 Table-mounted Routing 5 02-17-2008 11:36 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
