screw clamp storage - Router Forums
 25Likes
post #1 of 22 (permalink) Old 08-19-2015, 09:47 AM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default screw clamp storage
I've read some of the posts concerning clamp storage but most deal with storing bar type clamps. I've seen store bought "solutions" to storing bar clamps but-----
Does anyone have an effective way/means to store the wooden screw clamps on an unfinished stud wall? Quantity is about 2 dozen, various sizes.
Currently I'm just screwing/tightening them to the stud and then hanging extras onto the handles.
There's gotta be a better way?!?!
Thoughts??
smitty10101 is offline
post #2 of 22 (permalink) Old 08-19-2015, 11:11 AM
First Name: Ed
I only have a few handscrew clamps mostly use bar clamps but that is what it I do basically same as you just clamp them to a shelf end or anything that out of the way
Justaworker likes this.
herrwood is offline
post #3 of 22 (permalink) Old 08-19-2015, 03:49 PM
Thoughts??
There is a method for storing the wooden hand screw clamps in this article - if you have open studs, you can modify what's shown to just having the projecting post screwed to the side of the stud rather than having the mounting flange in the back. For (4) clamps, the amount sticking out is probably going to be about the same as your present method but you won't have to tighten and then loosen when you're using them.
tomp913 is offline
post #4 of 22 (permalink) Old 08-19-2015, 10:44 PM
RainMan 2.0's Avatar
I'm liking the #5 in the photo . Going to use it for sure , thanks Tom
Ok ,I never insulate
RainMan 2.0 is offline
post #5 of 22 (permalink) Old 08-20-2015, 08:17 AM
First Name: Art
I clamp mine to the ceiling/floor joists all it takes is one twist to get them on or off.
Name:	clamp storage 001.jpg
mgmine is offline
post #6 of 22 (permalink) Old 08-20-2015, 08:21 AM
Geez I'd be wearing a hard hat
DaninVan and koolrebel like this.
post #7 of 22 (permalink) Old 08-20-2015, 08:49 AM
First Name: Gary
Smitty, Here is a quick thought. And I also have it in a Sketchup file if interested, But since Router Forum WON'T ACCEPT SKP Files I would have to zip it.
ksidwy and Roy Drake like this.
gmercer_48083 is offline
post #8 of 22 (permalink) Old 08-20-2015, 08:54 AM
First Name: Gary
The cleat/handle allows it to be cleated to a wall or used as handles to carry it. As drawn it will hold up to 5 large clamps and has a gap to allow dust to fall thru.
post #9 of 22 (permalink) Old 08-20-2015, 09:43 AM
First Name: Gary
Here is the sketchup file in zip form
post #10 of 22 (permalink) Old 08-20-2015, 11:04 AM
I only have four of these, So I lay them horizontally on a dedicated shelf. They are all laid on the same side so they can overlap. Wall space is nice, but I don't use them often enough to use that precious commodity for that kind of clamp. The shelf is only 6 inches wide and runs between two much wider shelves. Out of the way, but still handy.
Craftsman scroll saw part? Birch Wood Scrolling 9 09-11-2016 07:36 PM
Clamp storage idea matt1710 Tools and Woodworking 6 11-16-2011 01:52 PM
Delta Quickset II Blade Clamp screw- holddown screw rstermer Wood Scrolling 2 09-25-2008 10:21 PM
How To Destroy Screw Heads cabinetman Lobby 4 06-09-2007 06:03 AM
