Best way to clean shipping 'grease' off new router bits? - Router Forums
post #1 of 5 (permalink) Old 03-01-2008, 09:26 AM Thread Starter
Default Best way to clean shipping 'grease' off new router bits?
Ok, newbie question: what is the best way to clean the grease off new router bits without pulling the lube off the bearings of piloted bits?
Is just wiping it off sufficient, or do I need to remove it more completely to not wind up with gunk in my collet?
(if this is not the case with all router bits- my MLCS bits came with a thin coating of some kind of grease or anti-corrosion goop)
Gator95 is offline
post #2 of 5 (permalink) Old 03-01-2008, 09:40 AM
Hi Gator95
I use the items below for that job,, you can also get the same type of stuff at most woodworker supply outlets but I do like the sommerfeld brand it's works..
SOMMERFELD'S OWN BIT & BLADE
http://www.sommerfeldtools.com/item....16oz&d=160&b=2
SO BIT & BLADE LUBRICANT 2oz
"This unique liquid fluoropolymer spray"
http://www.sommerfeldtools.com/item....d2oz&d=160&b=2
I also use the DuPont Teflon lub I got from ACE hardware it also works well, it cleans and lubs the bit all in one shot...puts on a thin coat of Teflon on the cutters , slick stuff
Locktite DuPont Krytox PTFE High Performance Lubricant
http://www.sandsmachine.com/grease_t.htm
fluoropolymer = http://en.wikipedia.org/wiki/Fluoropolymer
post #3 of 5 (permalink) Old 03-01-2008, 12:09 PM
Large bottle of alcohol from Wal-Mart thatís less than $2.00
And a large DW40 thatís less than $5.00
Router is still my name is offline
post #4 of 5 (permalink) Old 03-01-2008, 02:06 PM
Hamlin's Avatar
First Name: Ken
Hi Gator,
I like to use Brake Cleaner due to the fact it evaporates and leaves no residue. Don't spray it on the bearings though.
Router has listed a cheap way that works great.
Bj has listed an excellent product,
There's many ways to clean your bits.
Ken
"A VETERAN"
Hamlin is offline
post #5 of 5 (permalink) Old 03-01-2008, 08:59 PM
First Name: Joe
Send a message via MSN to petersenj20
One here for denatured alcohol. I also used it to clean the tablesaw top before waxing
petersenj20 is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
