Hitachi M12V2 - Fine Adjustment Problem - Router Forums
post #1 of 4 (permalink) Old 03-05-2008, 10:52 AM Thread Starter
Default Hitachi M12V2 - Fine Adjustment Problem
Has anyone had any problem using the fine adjustment on this router. The Instruction book is not very good. I think there are mistakes in the translation from Japanese. Anyhow I have spent two days trying to get it to work without success. Your help will be greatly appreciated.
Mc
mcelduff is offline
post #2 of 4 (permalink) Old 03-05-2008, 12:11 PM
First Name: Joe
Mc
If you are referring to the tube with a big knob on it that comes as an accessory, it will not work if you remove the springs. The assembly is pretty easy, just look at the pictures (mine came with them from Amazon a few years ago). I tried it, but saw little need for it since I use my Hitachi primarily in an OP table and the adjustment knob was just in the way. Maybe if you would describe your specific problem, with the fine adjustment, I could help a bit more. I just wish they had not discontinued this model.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline
post #3 of 4 (permalink) Old 03-05-2008, 04:22 PM
I believe the sequence is:
1. plunge the router to the approximate depth you want.
2. lock the router in place with the flip lever (left side if facing the side of the router with the levers on it).
3. turn the lever on the micro adjuster (right lever) counter clockwise (this engages the twisty knob thredded shaft thingy).
4. release the locking lever.
5. twist knob on micro adjuster to achieve the desired depth.
I think the manual says something about not making adjustments by turning twisty knob when the lock lever is engaged too.
This is all from memory so please double check what I say against the instructions.
Sorry for the non-technical terms.
I personally hate the micro adjuster on the m12v2 but it is a cheap, powerful router.
Good luck,
Erik
elamber is offline
post #4 of 4 (permalink) Old 03-07-2008, 09:30 AM
Julie's Avatar
First Name: Julie
Hi Mc
Is this a newer model Hitachi? Mine is about 4-5 years old and I use the micro-adjuster all the time to set the height of the bit, every time I use my router while it's hanging in the table. It's very precise, I love it, except for the fact that they've designed it to sit right beside where the electrical cord comes out of the body of the machine.
Perhaps you could explain what the problem is? I have my instruction book which might help, I just need some idea of what isn't working for you. Do you have it installed correctly?
~Julie~
Julie is offline
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 04:30 PM
hitachi m12v2 router fence cabin General Routing 2 12-01-2007 12:36 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 10:34 PM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-19-2005 12:22 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 07:50 AM
