A new Musclechuck - Router Forums
 10Likes
  • 10 Post By Mike
post #1 of 5 (permalink) Old 08-27-2015, 07:47 PM Thread Starter
Default A new Musclechuck
Few companies listen to their customers the way Musclechuck does. On request an extended version of the Type 1 is now available. The new Musclechuck Type 1E is 1/2" longer than the standard Type 1. In comparison to the factory collet/nut this is about an additional 1-1/8" of reach. That should be enough reach for most tray templates without an extension.
rcp612, Web Shepherd, MYB and 7 others like this.
post #2 of 5 (permalink) Old 08-28-2015, 11:29 AM
JFPNCM's Avatar
First Name: Jon
@Mike
Great idea. One question, how does the diameter of the collet, including the set screw compare to the diameter of the bearing on the majority of bowl bits? The diameter of my original Musclechuck for example is significantly larger than the bearings on both my bowl bits.
Jon
JFPNCM is offline
post #3 of 5 (permalink) Old 08-31-2015, 05:15 PM
hawkeye10's Avatar
First Name: Don
Now that makes it more tempting to buy one. Not having to buy an extension helps absorb the price of the MC. After buying my new table saw I am going on food stamps.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 5 (permalink) Old 09-01-2015, 08:56 PM Thread Starter
Bad news, although the 1E has the height for bowl and tray templates the diameter is too large. At this time the largest diameter bowl and tray bit offered is 1-1/4". These bits have a 1/4" radius. Infinity Tool offers an extension with an OD of .118" that is designed to work with these bits. The Xtreme Xtension measures .135" and to clear the screw the Musclechuck would require a bit with a 1-1/2" diameter.
I am going to get on the phone and see about getting a bit manufactured with this diameter.
post #5 of 5 (permalink) Old 09-01-2015, 10:50 PM
JFPNCM's Avatar
First Name: Jon
@Mike
Thanks Mike. I thought that would be the case.
Jon
JFPNCM is offline
MuscleChuck vs Whiteside Eliminator...huh...? Nickp Router Bits - Types and Usage 38 06-09-2015 10:40 PM
Musclechuck N'awlins77 Jigs and Fixtures 28 02-13-2015 06:39 AM
Musclechuck hex key storage 48394 Table-mounted Routing 3 07-15-2014 07:24 PM
At last, a MUSCLECHUCK for the early TRITON routers harrysin Lobby 1 06-07-2014 12:18 AM
Installing a Musclechuck Mike General Routing 6 04-26-2014 01:20 PM
