dewalt router 618pk - Router Forums
 2Likes
post #1 of 14 (permalink) Old 08-30-2015, 11:15 AM Thread Starter
First Name: fred
Default dewalt router 618pk
Hey guys I'm considering buying the dewalt 618 pk package. Its mostly for small projects I would like to do around the house. I would like to build some cabinets in the future and started wondering if this router can handle the big bits. I'm talking about the raised panel bits (for cabinet doors). I currently own a 2 hp craftsman router with a 1/4" in collet, and really like the idea that the dewalt comes with both the 1/4 and 1/2" collets. Would love some feedback on this especially if you have had first experience.
fast freddy is offline
post #2 of 14 (permalink) Old 08-30-2015, 12:53 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum.
The 618 is a good all around router,for the larger bits you need to take smaller bites but will get the job done
Thank You John
Semipro is offline
post #3 of 14 (permalink) Old 08-30-2015, 01:08 PM
Honored Member
First Name: pat
Would not subject the 618 to heavy loads, especially in light of its motor's checkered history.
Quillman is offline
post #4 of 14 (permalink) Old 08-30-2015, 02:45 PM
The good news is parts are readily available, I am sure you will be taking advantage of this.
post #5 of 14 (permalink) Old 08-30-2015, 02:46 PM
Contributor of the Month
I have that router and have been very pleased with it. I haven't done anything as big as raised panels. As previous poster said it's usually best to route in small increments....especially with hard or splinter prone woods. The kit I got had a fixed based, plunge, and D handle. I've used it to make rail and style cabinet doors, hardwood flooring work, etc. and it has never disappointed. Works well in a table and also comfortable for hand held work. Bosch and PC are also good options in this size.
JIMMIEM is offline
post #6 of 14 (permalink) Old 08-30-2015, 02:57 PM
MT Stringer's Avatar
Welcome aboard, Freddy.
I don't have any experience with the DW router. Mine are Bosch, and Triton.
I used the Bosch 1617 to cut raised panel doors from poplar glued up panels and it worked OK. I ran it at the slowest speed and made several passes (moving the fence a little before each pass) until I got the desired result.
By the time I was ready to make more panels, I had bought the Triton 3 1/4hp router. It just loafs along making the cuts.
I do have some good advice for you that is related...
If you buy a router insert plate for a table, make sure the opening is large enough for the big cutter to fit through. My original router table had a Rockler Group "A" plate. The Freud cutter was bigger than the opening so I couldn't use it. I finally added a 1/8th inch masonite aux table top with a larger opening in it, installed the cutter from above the table, and had just enough adjustment to set the cutting height I needed.
I solved that dilema by purchasing a Kreg plate. It has a larger opening. Actually, I bought two, one for the Bosch and one for the Triton.
Here are some reference links to what I am talking about.
Hope this helps.
Adjustable Height Workstation
http://www.routerforums.com/show-n-t...able-more.html
Bosch 1617EVSPK Router Combo Kit
http://www.routerforums.com/general-...combo-kit.html
Exact width dado jig.
http://www.routerforums.com/jigs-fix...-dado-jig.html
Name:	2013-10-15 19.51.52.jpg
Name:	2013-10-15 19.52.04.jpg
Name:	2013-10-15 19.52.25.jpg
Name:	2013-10-15 21.44.19.jpg
Name:	2013-10-15 21.44.39.jpg
Name:	2013-10-18 15.24.12.jpg
Name:	2013-10-23 17.16.15.jpg
Name:	2013-10-23 17.16.36.jpg
Name:	2013-10-28 10.28.15.jpg
MT Stringer is online now
post #7 of 14 (permalink) Old 08-30-2015, 03:04 PM
Nice work. Sharp lines and tight joints. How did you like working with poplar?
MT Stringer likes this.
JIMMIEM is offline
post #8 of 14 (permalink) Old 08-30-2015, 03:07 PM
I like it a lot.
post #9 of 14 (permalink) Old 08-30-2015, 03:23 PM
Checked out the DeWalt and really didn't like the feel of the height setting. Got the Bosch 1617 EVSPK kit instead and have never regretted it. Got a second motor for the table, then moved it to the plunge base when I put a Triton TRA001 in the table. I used to like DeWalt's tools, but I'm less impressed after buying Bosch tools.
post #10 of 14 (permalink) Old 08-31-2015, 08:42 AM
Ccrew's Avatar
First Name: Roger
I agree. I've also had good results with Hitachi stuff but my Bosch stuff is king of the shop.
Ccrew is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
I need a shop vac hose for a DeWALT DW618 router Duane Bledsoe Tools and Woodworking 27 06-15-2015 09:13 AM
General router accessory questions, some DeWalt specific, some not Duane Bledsoe General Routing 27 02-07-2015 09:08 PM
