Using MDF - Router Forums
 16Likes
post #1 of 26 (permalink) Old 09-24-2015, 06:32 PM Thread Starter
First Name: Fred
Default Using MDF
I intend to use a 1" flush trim bit on 3/4' MDF. Am I setting myself up for failure or disappointment with the results?
spike1 is offline
post #2 of 26 (permalink) Old 09-24-2015, 06:36 PM
RainMan 2.0's Avatar
Welcome to the forum . I'm are the resident experts will have an answer for you shortly .
All I know is wear a good quality mask when working with mdf
spike1 likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 26 (permalink) Old 09-24-2015, 06:48 PM
The only thing I've found a use for MDF is as a spoilboard on the
CNC machine. That stuff is terrible to work with and has virtually no strength and crumbles and breaks and is heavy and ........
It was a major disappointment when I tried to work with it.
HJ
And I got 2 sheets of it in the basement
JFPNCM, Shop guy and Stick486 like this.
honesttjohn is online now
post #4 of 26 (permalink) Old 09-24-2015, 06:56 PM Thread Starter
First Name: Fred
Thanks for the input. I wanted to use stuff I had laying around my shop and save $ on new purchases. i figured if I was careful with pilot holes and glue, that the spare MDF I had might be a decent substitute for plywood. The project is a shop vac/dust cyclone cart which won't receive a lot of abuse. We'll see. Thanks again.
spike1 is offline
post #5 of 26 (permalink) Old 09-24-2015, 07:40 PM
Mdf has it's uses but in that one I think you would be better off with ply. One of the biggest problems you would have with that is the screws holding the wheels on. It also wouldn't take bumps that well.
post #6 of 26 (permalink) Old 09-24-2015, 08:01 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
spike1 likes this.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #7 of 26 (permalink) Old 09-24-2015, 08:32 PM
First Name: Richard
Using mdf for most things is just an invitation to disaster. I like to save money as much as the next guy and some say more than most but Mdf is not the way. So save yourself some frustration and bite bullet and buy plywood.
Shop guy is offline
post #8 of 26 (permalink) Old 09-25-2015, 02:05 AM
hawkeye10's Avatar
First Name: Don
This mantle clock is 100% MDF. It cuts and routs very good but when it comes to finishing there is where I had problems. It soaks up finish like crazy, especially where you rout and cut with a saw. I used Zinsser Bulls Eye 1-2-3 to prime with. You might prime twice or three times before putting on a top coat. Try testing on some scrap. If I had known about how much you need to prime MDF my finishing would have gone a lot better. I am sure you know that they have been making routed cabinet doors from MDF for years.
Zinsser Bulls Eye 1-2-3 1 gal. White Water Based Interior/Exterior Primer and Sealer-2001 - The Home Depot
You can also get this primer in a rattle can and spray it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 26 (permalink) Old 09-25-2015, 08:29 AM
The Hobbyist's Avatar
First Name: Joe
Originally Posted by honesttjohn View Post
+1
CNC machine.
Have you tried this large sheets of flat (blue or pink) high density foam as a spoil board? They work GREAT, they save the tool, they do not add a load to the CNC machine, and they are really CHEAP when you want to do a test run in a wood-like material to make a prototype of whatever you are going to cut out of the more expensive material afterward.
honesttjohn likes this.
The Hobbyist is offline
post #10 of 26 (permalink) Old 09-25-2015, 08:51 AM
Honored Member
First Name: pat
If your 1" cutter is the standard 1/2"D trimmer with an R-3 (3/16 x 1/2) bearing on it, you are looking for trouble. Whilst that cutter is capable of wasting a lot of MDF, it will chatter the work; it deflects. Use a bigger cutter, at least 3/4"D.
Most chip/dust collectors will clog, do this outside.
In my view, it will hold fasteners acceptably, work as lab surfaces and is useful for first run templets.
Uses MDF for all sorts of applications.
Quillman is offline
Dyson for MDF praveendv Tools and Woodworking 5 04-07-2014 03:28 AM
Using Barrel Nuts In MDF Jig Gaia Jigs and Fixtures 15 06-19-2012 04:17 PM
Help with creating dado for MDF JohnnyAbe General Routing 19 04-22-2012 01:56 AM
MDF Stability for Kitchen Doors slennon DIY and Renovation 10 03-16-2012 01:11 AM
Contact Cement for MDF Cassandra Table-mounted Routing 28 04-30-2010 10:39 PM
