Tool Mover - Router Forums
 36Likes
post #1 of 18 (permalink) Old 10-07-2015, 01:37 PM Thread Starter
old coasty's Avatar
First Name: Bob
Default Tool Mover
Being part off the older not as strong as I used to be generation (old Geezers) I need help moving heavy tools.
Therefor, I developed a system, that suits me. Maybe others can use it, revise it, or whatever.
My built in workbench is the storage area for some tools.
1/2” PVC pipes run front to back on the bottom shelf to slide tools on. !” PVC pipes divide slots for tools to keep them from getting cross ways.
Tools are mounted on 3/4” plywood 24” long, and width appropriate to the tool.
The Tool Mover is a HF movers gizzy with the carpet removed and 3 2x4’s screwed on it to raise it up with 1/2” PVC pipes fastened sideways to be at a good level for the tool bases.
There is a Dewalt chop saw/planer stand with a plywood base involved.
The tool I want to use sets under the workbench. I move the Tool Mover to the edge of the bench, and slide the tool on to it.
Then I go to the Dewalt laying down on the floor, and slide the tool up onto it
After clamping the tool base to the base on the Dewalt, depending on the tool, I raise the dewalt all the way up.
Or only partway up.
The tool can be stored on the Dewalt upright to save space if it will be used again before some other tool
Reverse everything and all’s back in place and well. It also means due to mechanical advantage, I never pick up more than half the weight of the tools.
There are some kinks that are still to be ironed out. I use Bessy Clamps right now to hold the tool base on the Dewalt base. I’m trying to figure out a final solution. T-Nuts and knob bolts are the current thought. Anyone have a better idea?
The Router Table you see is a temporary one, I scored three 22” x 36” Office Cubicle Desk panels the other day. They were consolidating 2 Office Furniture stores into one location, and these panels were free. Wish I had something besides a Prius when I was there, as there was lots on “free” big stuff. Anyway, one will be my Router Table Top. Guess if I screw one up, I have two more chances to get it right.
It looks like the Router Table Top will be approximately 3” higher than my Bosch Saw top when the Dewalt is at it’s lower level using legs for clearance. That will be very workable compared with the one you see setting on the Dewalt. That currently sits high up on top of my free standing “Work Bench”. Plywood on top of two warped 2x4’s on saw horses. Have made no attempt to fasten it to the Dewalt for use.
I was thinking about folding legs for the Router Table to be able to fold it up, take the Router off with it’s plate and store the top upright in brackets on the back of my real workbench which I’m designing.
However I am also considering hinging the Router Table Top to the back of my workbench so it can be used as part of the bench top for assembly or other use, yet folded down for storage. Make blank plate for the router plate hole. Would be easier on the old bones storing it.
I tried but failed to get the photos in the text. Maybe next time. Cricket told me how to do it, but the old brain cells revolted.
Name:	#2  2015-09-13 Tool Mover 10.38.19.jpg
Name:	#3  2015-09-13 Dewalt Stand10.37.33-1.jpg
Name:	#4  2015-09-13 Tool mover ready10.40.18.jpg
Name:	#5  2015-09-13 Tool Mover loaded10.41.17.jpg
Name:	#6  2015-09-13 Tool Off Mover on Stand 10.43.04.jpg
Name:	#7  2015-09-13 Tool on Stand Folded10.58.29.jpg
Name:	#8  2015-09-26 Tool on lower eight16.07.10.jpg
Name:	#9  2015-09-26 Tool on top height15.26.56.jpg
Name:	#0  2015-09-13 Tool Shelf Empty10.47.24.jpg
Name:	#1  2015-09-13 Tools in Place10.38.58-3.jpg
kp91, Mike, rcp612 and 15 others like this.
old coasty is offline
post #2 of 18 (permalink) Old 10-07-2015, 01:53 PM
kp91's Avatar
First Name: Doug
That's a nifty way of storing and lifting them into position!
Necessity and old age is the mother of invention!
Bricknhank and old coasty like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 18 (permalink) Old 10-07-2015, 04:01 PM
Heh,Heh, good thinking, sure a slick way to move the tools around.
old coasty likes this.
Herb Stoops is offline
post #4 of 18 (permalink) Old 10-07-2015, 07:27 PM
First Name: Ed
Looks like a good set up.
herrwood is offline
post #5 of 18 (permalink) Old 10-07-2015, 08:05 PM
RainMan 2.0's Avatar
Bob you've got some creative ideas . Nice work
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 18 (permalink) Old 10-08-2015, 06:44 AM
Nickp's Avatar
First Name: Nick
Love your setup...
Can you provide more information about the "movers gizzy"...can't seem to find it...
Thanks for sharing...
Nick
Nickp is online now
post #7 of 18 (permalink) Old 10-08-2015, 06:47 AM
salvation for bad backs...
HOORAY...
pretty cool execution...
Stick486 is offline
post #8 of 18 (permalink) Old 10-08-2015, 08:23 AM
kp91's Avatar
First Name: Doug
Originally Posted by Nickp View Post
Love your setup...
18 In x 12-1/4 In 1000 lb. Capacity Hardwood Dolly
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 18 (permalink) Old 10-08-2015, 08:33 AM
CharleyL's Avatar
First Name: Charley
I have a similar stand made by Delta that I've attached my DeWalt 735 planer to. It has been a real back saver when I need to move and store the planer, but I never thought of using the stand with multiple tools. You have a great idea and I may use it.
Thanks,
Charley
Central North Carolina
CharleyL is online now
post #10 of 18 (permalink) Old 10-08-2015, 08:34 AM
Country: Brazil
First Name: sid
Very handy and safe way to move tools, Bob! It reminds me aircraft cargo roller systems. No matter what age we are, its always a good idea to preserve our spine. Congrats and thanks for posting!
Sid.
kp91, RainMan 2.0 and old coasty like this.
ksidwy is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 03:33 PM
Tool Definitions: tvman44 Lobby 22 07-12-2015 06:10 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 10:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
