Colt bit question? - Router Forums
 3Likes
  • 2 Post By phillipdanbury
  • 1 Post By DonkeyHody
post #1 of 6 (permalink) Old 10-08-2015, 09:27 AM Thread Starter
First Name: Eugene
Default Colt bit question?
Just got a bosch colt, what are some most used bits that I should have on hand so I can be prepared for most projects? I am one of those guys who rather have and not need than need and not have, thanks for all of your help..
Eugd is offline
post #2 of 6 (permalink) Old 10-08-2015, 09:45 AM
First Name: Phillip
We could collectively recommend many bits, some of which you may never use.
I suggest you wait until you have a planned project, then buy the needed bit.
Gaffboat and Roy Drake like this.
To change the world, change your mind.
phillipdanbury is offline
post #3 of 6 (permalink) Old 10-08-2015, 11:09 AM
DonkeyHody's Avatar
First Name: Andy
OK, I'll bite. You can't go wrong with a couple of round-over bits. I use 1/4 and 3/8 radius a lot. You'll eventually need a flush trim bit. And a straight bit about 3/8 diameter. Don't waste time on anything that isn't carbide tipped. Everything above except the straight bits should have ball bearing guides, not a smooth place at the end of the shaft to serve as a guide.
Cherryville Chuck likes this.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #4 of 6 (permalink) Old 10-08-2015, 11:49 AM Thread Starter
First Name: Eugene
Thanks I already have the 1/8 bit and will pick up the other 2
Eugd is offline
post #5 of 6 (permalink) Old 10-08-2015, 01:22 PM
The Colt is a good size for making signs. If that interests you the 60 and /or 90* vee point bits and a flat tipped sign making bit.
post #6 of 6 (permalink) Old 10-08-2015, 07:40 PM Thread Starter
First Name: Eugene
That's good to know about the signs thanks
Eugd is offline
Dovetail bit question 8 degree versus 14 degree. Timmberman Router Bits - Types and Usage 9 07-04-2018 10:27 AM
Lock Miter Bit Question MT Stringer Router Bits - Types and Usage 11 10-23-2014 10:45 AM
Question about rabbeting bit sets LBrandt Router Bits - Types and Usage 2 07-19-2009 05:07 PM
Bit for jointing question dabeeler Router Bits - Types and Usage 11 11-13-2007 10:57 AM
