Craftsman Plunge 315.268350 - Router Forums
post #1 of 4 (permalink) Old 04-16-2008, 07:53 PM Thread Starter
Default Craftsman Plunge 315.268350
bought this large 3.5 hp router from sears as a closeout. Seems to be a lot of friction in the plulnge mechanism. So much so that I cant use it mounted in the table. I have taken it apart and notice that one of the holes for the plunge bars is metal and the other has some sort of liner material, looks like plastic. Parts manual gives me no clue as to why one is different. Is there anywhere to have this alignment checked to see if one of the bars could be bent a little. When attempting to raise the unit under the table, the unit cocks and will neither raise or lower. Please help if you can. Thanks, WC
WCicotte is offline
post #2 of 4 (permalink) Old 04-16-2008, 08:06 PM
Hi WC
Sounds like it maybe jamming just a bit..
You may want to try some graphite, not oil/lub/WD40,, it will pickup saw dust unlike the graphite.
Comes in a little plastic tube..and is easy to put in place..
You can also use the DuPont dry lub (Teflon ) it coats the parts with Teflon. (it comes in a small plastic bottle ) but it's not as nasty as the graphite...(pencil lead) stuff.
post #3 of 4 (permalink) Old 04-16-2008, 10:35 PM
jer760's Avatar
First Name: Jer
Maybe the motor isn't sitting in the base snuggly, grab a screw driver and go around the router and try that. Another possibility is that the base needs to be shimmed in order to stop the plunge bars from binding.
Jer
Miracle Stick! Made of tough, genuine wood!
jer760 is offline
post #4 of 4 (permalink) Old 04-17-2008, 12:49 AM
WC, you did not mention if you had removed the plunge springs? These springs are most often removed for under table mounting. There are many different designs and some routers may have additional requirements for table mounting.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 11:29 AM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 08:54 PM
Craftsman Fixed and Plunge Base Combo Review..... challagan General Routing 49 01-03-2008 01:06 PM
Craftsman plunge router SHARKEY General Routing 3 11-21-2007 02:23 PM
