Routing door lip/finger grip on rails and stiles - Router Forums
 3Likes
  • 2 Post By preacher
  • 1 Post By BOjr
post #1 of 10 (permalink) Old 10-20-2015, 04:02 AM Thread Starter
Default Routing door lip/finger grip on rails and stiles
Hello, my first post.
I am making a door for a kitchen cabinet.
My question is, when do I rout the door lip/finger grip on the outside edge of the door?
Should I rout the door lip/finger grip on the rails and stiles prior to assembling of the door, or assemble the door, and rout all four sides on the completed door.
Thanks in advance for any and all replies.
Bbatman is offline
post #2 of 10 (permalink) Old 10-20-2015, 05:44 AM
waynecochran's Avatar
First Name: Wayne
I think you should route the profile before assembly. If you do it after you will have end grain at each corner that will chip out easily.
waynecochran is offline
post #3 of 10 (permalink) Old 10-20-2015, 06:45 AM Thread Starter
Thanks Wayne, that was the main concern I had.
Bbatman is offline
post #4 of 10 (permalink) Old 10-20-2015, 07:46 AM
before in case of tear out..
post #5 of 10 (permalink) Old 10-20-2015, 07:48 AM
Two other considerations. The smaller pieces are probably going to be easier to handle than a whole door. And if something should go wrong you only lose the one piece, not the whole door.
post #6 of 10 (permalink) Old 10-20-2015, 08:25 AM
if you have to route the finger grip afterwards rout only the long grain...
post #7 of 10 (permalink) Old 10-20-2015, 08:53 AM
First Name: Jerry
routing before assembly makes it difficult to edge the end of the styles. I always rout the edges of the completed door. It's much easier to handle the door. Never had any problem with tear out.
DaninVan and tomp913 like this.
preacher is offline
post #8 of 10 (permalink) Old 10-20-2015, 09:07 AM
I like a small round over on the outside (facing) edge) of the door and a stopped finger groove cut with a cove bit on the back edge. A little hard to see in this photo, but it's on the edge just below the center rail. On the lower cabinets, I've sometimes cut the finger hold on the top edge as an alternate to the edge, the upper cabinets varies from the bottom edge and the side at the lower part of the door, probably 3 - 4" long depending on the door.
tomp913 is offline
post #9 of 10 (permalink) Old 10-20-2015, 09:17 AM
I've done the same as Tom where I only put the finger grip on the bottom middle of the drawers and just the top rail or short section of the stile.
post #10 of 10 (permalink) Old 10-20-2015, 09:22 AM
First Name: Buck
I always make the stiles and rails a little larger than the finished width and height. This way when I clamp them together I don't have to worry about clamp marks on the wood. It is then easy and quick to run them through the table saw for the exact dimention that I want. I don't try to run the door through a router table if it is a large door. I hand hold the router. If I'm worried about tearout a small sacrificial piece of wood can be clamped to the door.
DaninVan likes this.
BOjr is offline
stiles and rails off by a 32nd... dvto2 Table-mounted Routing 7 10-14-2013 05:59 AM
Glueing panels to Stiles and Rails Kelwing2132 Tools and Woodworking 4 12-23-2011 09:07 AM
bit adjustment for rails and stiles denny14 Table-mounted Routing 5 04-14-2009 04:23 PM
Rails & Stiles sauk_98 Guide Bushings and Templates 4 12-17-2007 03:08 PM
Routing Stiles for RP Doors randytank Table-mounted Routing 2 09-15-2004 08:44 PM
