Ryobi twist adjustment - Router Forums
 1Likes
  • 1 Post By schnewj
post #1 of 5 (permalink) Old 10-23-2015, 08:01 AM Thread Starter
First Name: Jerry
Default Ryobi twist adjustment
I was given a Ryobi router set. The number on the "D" handle is R181D. It also has a plunge casing. These are used with routers RE1802M or R1801M. The motor is 10 amp. The depth adjustment is by twisting the outer case. The outer case is extremely difficult to turn and make an adjustment. Is this worth trying to fix and how do I do so. Thanks. Jerry
Loophole is offline
post #2 of 5 (permalink) Old 10-23-2015, 11:14 AM
schnewj's Avatar
SOP
Disassemble, clean, polish/buff motor and inside of the base. Use paste wax, reassemble and go back to work.
Mike likes this.
schnewj is offline
post #3 of 5 (permalink) Old 10-23-2015, 12:13 PM
If it has a toggle type tightened it may need to be loosened a turn.
post #4 of 5 (permalink) Old 10-23-2015, 01:08 PM
schnewj's Avatar
Good point. Thanks Chuck
schnewj is offline
post #5 of 5 (permalink) Old 10-29-2015, 03:38 PM
Originally Posted by schnewj View Post
SOP
should put that on auto play...
Ryobi T hand for table height adjustment ? MuzzleMike General Routing 13 11-26-2017 01:32 PM
Ryobi depth adjustment stuck arigger General Routing 27 03-12-2016 12:26 AM
ryobi r1801m1 hieght adjustment tight bubbabear General Routing 11 09-27-2013 06:19 PM
New router use w/ Ryobi 1801M1 router 1/4 inch collet RexM Router Bits - Types and Usage 1 04-11-2011 04:37 PM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
