Type of jig?? - Router Forums
 14Likes
post #1 of 14 (permalink) Old 10-25-2015, 08:40 AM Thread Starter
First Name: Pat
Default Type of jig??
I'm thinking I need a jig to accomplish the outline routing like in this example?
Murtu01 and RainMan 2.0 like this.
Belg is offline
post #2 of 14 (permalink) Old 10-25-2015, 10:32 AM
First Name: David
have you looked on amazon at the letter stencil kits,
stencils come in different sizes to
Davidrd is offline
post #3 of 14 (permalink) Old 10-25-2015, 12:20 PM Thread Starter
First Name: Pat
its not the letters I need help with its the parallel line all the way around the entire sign.
Belg is offline
post #4 of 14 (permalink) Old 10-25-2015, 12:31 PM
If you had the same pattern but about an inch in on all sides you could use a pattern bit or straight bit and template guide bushing.
Herb Stoops likes this.
post #5 of 14 (permalink) Old 10-25-2015, 06:58 PM
Frankj3's Avatar
First Name: Frank
Pat, I use a straight edge and clamps to make lines like these.
Measure from the outside edge of the bit to the outside edge of your router base. Mark a light pencil line this distance from the location of the line you want to cut. Then clamp a straight edge in place on the pencil line, check your location again by raising the bit just above the surface of the board. Eyeball it to make sure everything is correct. Set the depth of cut and cut the line.
This is a little time consuming at first. But once you get the hang of doing it this way it won't take you as long to do this each time.
Good luck!
ksidwy likes this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #6 of 14 (permalink) Old 10-25-2015, 09:04 PM
Good luck!
Frank, I can see your method working on the straight lines, but how would you set up for the corners? Just curious.
Belg likes this.
Herb Stoops is offline
post #7 of 14 (permalink) Old 10-26-2015, 05:03 PM
Frankj3's Avatar
First Name: Frank
Herb, I would cut them freehanded.....I'd take shallow cuts and go slow. I would increase the depth and retrace my tracks......slow and easy.....until I reach the desired depth.
Wish that I had a better answer.....but this rookie doesn't.
Frank
Frankj3 is offline
post #8 of 14 (permalink) Old 10-26-2015, 06:45 PM Thread Starter
First Name: Pat
Frank, I appreciate your suggestion but like in the pic shown I do have the curve to deal with and my OCD wouldn't accept a freehand cut version. Maybe if I was more experienced at it I could get away with it.
I think I'll use the template routing suggested by Chuck, I could use the smaller one for a later sign and save it as a template for future signs.
Frankj3 and Herb Stoops like this.
Belg is offline
post #9 of 14 (permalink) Old 10-26-2015, 09:22 PM
Pat if you make one to to your satisfaction with the straight sides and curved corners you can make another smaller one by hand with more than reasonable accuracy. If you take a thin board and put a peg through it that will follow the outline of the original and drill a hole for a pencil where you want the outline of the smaller jig to lie then you merely have to trace from the larger to make the smaller one. Of course you want to stay perpendicular to the edges and the curves but you would have to be off vertical to them by at least 10 degrees before it starts to become noticeable, something that is easily acheivable by eye.
Belg likes this.
post #10 of 14 (permalink) Old 10-27-2015, 06:26 AM
Nickp's Avatar
First Name: Nick
How about routing the radius first like routing a small circle and THEN cut out the radius. This would leave you some wood for a center pin that you can remove later...
Just thinking outside the circle...
Belg and Herb Stoops like this.
Nick
Nickp is online now
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 07:37 PM
My First Jig Coleve Show N' Tell 14 03-10-2013 08:12 PM
Incra Jig Process Imporovement tprofera Jigs and Fixtures 21 09-18-2012 08:45 PM
mortise pal jig 46_trap Tools and Woodworking 1 03-31-2008 11:02 PM
