Porter router 7518 problems (URGENT!!!!!!) - Router Forums
post #1 of 3 (permalink) Old 04-30-2008, 10:09 AM Thread Starter
Default Porter router 7518 problems (URGENT!!!!!!)
Hello,
My name is Marc Brunet Gagne, and I'm working for S2K Identity Signs in Mexico City. We have a multicam router:
Model Porter 7518, Variable speed production router
Motor : 75182
120 V AC 15 amp
Type 1
Ser. no. : 999039
I use the software Motion Mechanic(multicam software) to make the link between the computer and the router.
I use the software EnRoute to make my pieces.
We are using the router on a router table.
We have severals problems:
1- The "Z" is not stable, sometimes it is going little bit upper, and sometimes it is going little bit down.
2- We ajusted the "X" and "Y" in the router program to be very precise and the day after, we have an error of at least 1/16" in each side undependently of the size of the piece we need to cut.
3- Sometimes, the machine is getting crazy, it is not able to recover the home machine, it is just staying in place and not moving.
I need an answer as soon as possible because our production is stop now because of those problems
Thank you
Best Regards
Marc Brunet Gagne
marc.brunet.gagne is offline
post #2 of 3 (permalink) Old 04-30-2008, 10:20 AM
Hi Marc
You may want to post your question on the forum below .
http://www.cnczone.com/forums/index.php
post #3 of 3 (permalink) Old 04-30-2008, 09:52 PM
Marc, the problems you are describing have nothing to do with the router motor. The motor will either run or not. Your problems are with several other things. The first step is to clean the entire work area being sure their is no debris in the servo motors which can cause bad readings. Check to be sure all mounting hardware on the servo motors and router is tight. These are the most common causes of failures. Next check the wiring connections to see if their is any damage or loose connectors. Beyond this you may have problems with either your programing or a controller part is failing.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
porter cable 7518 router cheapest I have seen toolman677 The Bargain Bin 1 09-23-2006 03:54 PM
