Need help: Routing a pencil holder on desk top - Router Forums
 4Likes
  • 2 Post By tomp913
  • 2 Post By Cherryville Chuck
post #1 of 5 (permalink) Old 10-28-2015, 06:37 AM Thread Starter
First Name: Greg
Default Need help: Routing a pencil holder on desk top
Hi
I need to route a single pencil holder on a desk top, similar to desk tops when I was growing up.
It would slope in at either ends of the slot.
Any help would be appreciated.
gregrlevy is offline
post #2 of 5 (permalink) Old 10-28-2015, 07:07 AM
Use a core box bit in a plunge router MLCS Core Box and Round Nose router bits This will give you a round bottom groove with a rounded end. Depending on where the groove is relative to the edge of the desk top, you may be able to use your router edge guide with stops clamped to the top to define the length of the groove or a straight edge clamped to the top, also with stops at each end.
ksidwy and Herb Stoops like this.
tomp913 is offline
post #3 of 5 (permalink) Old 10-28-2015, 08:04 AM
Like Tom says, a stopped groove with a round nose bit. If you want to make more that one groove i would make a pictire frame for a jig with the ends stopping the router at the length you want and if you want two or more parallel grooves then make it wide enough to add a shim(s) after you make the first groove.
post #4 of 5 (permalink) Old 10-28-2015, 10:55 AM Thread Starter
First Name: Greg
Thanks!!
post #5 of 5 (permalink) Old 10-29-2015, 09:02 AM
I believe you would use a Core Box Bit.
IRestore is offline
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Route through laiminate, or lamininate after routing? charleyb Table-mounted Routing 5 08-11-2009 01:46 PM
Routing a semi circle top for a picket fence village General Routing 19 05-30-2009 09:46 PM
Worse than BJ on steroids Bob N Jigs and Fixtures 24 04-18-2009 09:09 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
