Router bits for B&D 7620 router? - Router Forums
post #1 of 8 (permalink) Old 10-30-2015, 11:55 AM Thread Starter
Default Router bits for B&D 7620 router?
I retired last year and am finally getting around to making some sawdust. I'd like to try to use the B&D 7620 router I bought at a garage sale 10 years ago. I found a copy of the manual here. Thank you Router Forums very much! This router came with no bits. I have a Craftsman router bit kit I bought about 10 years ago also. I just measured and those bits have a 1/4" shank. From the manual, I see that my B&D 7620 router has a 1/4" collet.
Can I use these Craftsman router bits in this B&D router?
If it isn't obvious I have NEVER used a router before.
Any help, guidance, links to good information is greatly appreciated!
txlonghorn1989 is offline
post #2 of 8 (permalink) Old 10-30-2015, 12:20 PM
MikeMa's Avatar
You should be able to use those bits in your router.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 8 (permalink) Old 10-30-2015, 12:33 PM
Welcome to the forum. Any 1/4" shafted bit will fit either router.
post #4 of 8 (permalink) Old 10-30-2015, 02:46 PM Thread Starter
Thanks a lot for the quick replies guys! It is much appreciated! :0)
post #5 of 8 (permalink) Old 10-30-2015, 03:06 PM
MT Stringer's Avatar
Welcome aboard.
1/4 inch is 1/4 inch, so have at it.
BUT! When you insert the shank into the collet, bottom out the shank, the raise it slightly before you cinch the collet. That way, the collet won't jam the shank and make it hard to remove.
Search You Tube for "Router 101". There are several videos that should give you a jump start.
MT Stringer is offline
post #6 of 8 (permalink) Old 10-30-2015, 05:56 PM
Default Suggestion...
@txlonghorn1989
go to my uploads (http://www.routerforums.com/profile....1&showthumbs=1) and there are a PDF's on router safety, bits, use, maintenance and other general information...
those PDF's are downloadable if you want to start your own on hand library...
bring your lunch...
post #7 of 8 (permalink) Old 10-31-2015, 02:22 AM Thread Starter
Thanks Mike, Stick486!! I will do as you both suggested! :-)
post #8 of 8 (permalink) Old 10-31-2015, 02:29 AM
You may also like to take a look here:
http://www.routerforums.com/router-b...tml#post505441
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Replacement Router Bits for the Craftsman Router Crafter Brian in Burlington Router Bits - Types and Usage 1 11-17-2009 12:33 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 02:04 AM
