Freud Router Dove T Template - Router Forums
post #1 of 2 (permalink) Old 05-03-2008, 07:39 PM Thread Starter
Question Freud Router Dove T Template
As the statement says, hello everyone.
Question about template guides for the Freud FT 1700 VCE router. I have the guides sold by Harbor Freight, they seem great, but how does one attach the adapter that holds the collars. There should be a ring that fits around the adapter to hold in in place. The adapter has four screw holds but no way to fasten it to the base plate.
The one that said his Harbor Freight adapte just pops into place, well, that ain't so with this set up.
JRon is offline
post #2 of 2 (permalink) Old 05-04-2008, 12:19 AM
Hi JRon
See snapshots below plus the links below
Freud FT1700
http://www.freudtools.com/images/man...CEK-Manual.pdf
http://www.freudtools.com/t-manuals.aspx
http://www.amazon.com/Freud-FT2020-T...ol_ai_-2_3_tit
http://www.woodhaven.com/ProductDetail.asp?Id=2200
Applications
This adaptor plate can be used with Freud FT1700VCE, FT2000E, FT2200E, and FT3000 routers as well as many other popular routers. Template guides will work with any router or adaptor which accepts universal template guides.
What's in the Box
5/16, 3/8, 7/16, 1/2, 5/8, 51/64, and 3/4-inch templates, adapter, and carrying case.
Warranty
The unit comes with Freud's One-Year Limited Warranty.
From the Manufacturer
With this set you will always have the correct guide when you need it. The guides and adaptor are machined out of a special brass alloy for precision and long life. Set contains the following templates: outer diameters are listed- 5/16, 3/8, 7/16, 1/2, 5/8, 51/64, and 3/4-inch.
http://www.harborfreight.com/cpi/cta...emnumber=95160
Name:	freud base 1.jpg
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 09:23 AM
