Wood filler - Router Forums
post #1 of 4 (permalink) Old 05-04-2008, 10:11 PM Thread Starter
First Name: Steve
Default Wood filler
Is there a good wood filler someone can recommend? I use pine for the most part.
Steve Bolton
S Bolton is offline
post #2 of 4 (permalink) Old 05-05-2008, 12:20 AM
Hi SB
I use MinWax Stainable Wood Filler, comes in a yellow tube, little dab will do the trick, I mix the saw dust from the same stock with the filler to get it to blend in. also the tip below..
Works for me..
Name:	wood filter.jpg
post #3 of 4 (permalink) Old 05-05-2008, 08:52 AM Thread Starter
First Name: Steve
I wish I could draw things like that. If you don't use the tape does it stain the other wood?
sb
S Bolton is offline
post #4 of 4 (permalink) Old 05-05-2008, 09:57 AM
Hi SB
Well not so much stain but it seals the wood in away and it sometimes shows up at stain time or finish time, it will soak up the stain but it's just not the same, it's always tricky when using wood filler, it's one of the times a little is alot...
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Unknown, wet, wood Mitch12 Woodturning and Lathes 4 05-13-2008 01:48 AM
Router bit burning the wood!!! rovailla Router Bits - Types and Usage 7 07-18-2007 03:15 AM
Best wood filler? Birchwood Tools and Woodworking 4 10-11-2005 08:47 AM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 08:11 PM
