Acrylic routing problem - Router Forums
post #1 of 2 (permalink) Old 05-08-2008, 12:38 PM Thread Starter
Default Acrylic routing problem
Hello,
I'm working in a signs manufacture company and we are machining acrylic. Now the process is that we cut the acrylic with a CNC router, but the finish is not good so we need to sand it, after and we burn the edge to give a perfect transparent finish.
My objectif is to eliminate the sanding process because it is very long.
I tried several bits on the router to give a perfect finish, 1 flute, 2 flute, 3 flutes, spiral, straight, ... my main problem is that I don't know what RPM and feed to use to have a perfect finish and with with bit.
I want to make it in one pass.
Can you help me?
Thank you
Marc
marc.brunet.gagne is offline
post #2 of 2 (permalink) Old 05-08-2008, 02:04 PM
Hi Marc
You may want to post your question on the forum below..
http://www.cnczone.com/forums/index.php
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 10:12 PM
Freehand routing Visteonguy General Routing 53 07-12-2013 05:33 AM
Routing Oak ahosterman Router Bits - Types and Usage 9 10-30-2007 10:23 AM
tambour grooves routing problem glencross Portable Routing 6 07-21-2006 01:56 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 01:24 PM
