Freud 3 1/4 HP (1/4 collets) - Router Forums
post #1 of 3 (permalink) Old 02-08-2005, 11:04 AM Thread Starter
Question Freud 3 1/4 HP (1/4 collets)
Have recently purchase the Freud 3 1/4 hp router. I have enjoyed using this model but have run into a bit of a snag. Inserting the 1/4" collet has proven to be a task in itself. Does anyone know of an easy way to accomplish this. I have problems starting the threads on the collet retaining bolt. Tks in advance.
Del Delaplante is offline
post #2 of 3 (permalink) Old 02-08-2005, 11:37 AM
Make sure the collet is "clicked" into the nut. I have the same router and as long as the collet is secure in the nut, I have no problems getting the nut onto the router.
bmb in ab is offline
post #3 of 3 (permalink) Old 02-08-2005, 12:27 PM
This same collet design is used on older Bosch models. You need to tilt the collet slightly while inserting it into the nut. Other than that perhaps your nut has damaged threads? I would try taking the collet and nut to your retailer and compare it to the fit of a display model. If it fits different replace it, much cheaper than having to replace a shaft whose threads have been damaged. This should be a warranty item for you.
FREUD Dado Sets sawstop Tools and Woodworking 11 05-01-2010 01:00 PM
Freud 2200E and Bosch RA1171 Table 1973vw Table-mounted Routing 7 01-02-2008 04:45 AM
Freud Routers Bill A Tools and Woodworking 2 11-26-2007 07:47 AM
Freud FT3000 collet? ezatt Starting Off 4 01-19-2007 03:54 PM
Freud routers and tables cabinetsetc General Routing 6 11-06-2005 05:06 PM
