Plunge Router Issue - Router Forums
 11Likes
post #1 of 16 (permalink) Old 11-17-2015, 08:22 PM Thread Starter
berry's Avatar
First Name: Berry
Default Plunge Router Issue
I have a Bosch 1617 EVS PK. It's not had heavy use. Lately after a plunge cut, it won't easily return to the top position. I have to shake it or try to hold the base while pulling the motor up.
No doubt someone here will have advice on how to cure this little problem.
Thanks for reading.
May the grain be ever in your favor.
berry is offline
post #2 of 16 (permalink) Old 11-17-2015, 08:36 PM
Thanks for reading.
separate motor from base...
clean and polish both mating surfaces...
wax w/ furniture paste wax...
reassemble...
set the base clamp to persnickety setting...
berry, Shop guy and ksidwy like this.
post #3 of 16 (permalink) Old 11-17-2015, 09:11 PM
First Name: Earl
Also check/clean columns on plunge base--not used much might mean some accumulated crud. Johnson's paste wax on those as well.
earl
berry and ksidwy like this.
greenacres2 is offline
post #4 of 16 (permalink) Old 11-18-2015, 05:52 AM
Country: Brazil
First Name: sid
Originally Posted by Earl
...not used much might mean some accumulated crud.
+1.
Sid.
ksidwy is offline
post #5 of 16 (permalink) Old 11-18-2015, 02:17 PM
Cleanup as described and paste wax does it for me.
post #6 of 16 (permalink) Old 11-18-2015, 03:46 PM
vchiarelli's Avatar
First Name: Vince
.....and when you've done all of the above, put it to more use. We all get crickety when we're idle.
BrianS and DaninVan like this.
vchiarelli is offline
post #7 of 16 (permalink) Old 11-18-2015, 06:33 PM
hawkeye10's Avatar
First Name: Don
Paste wax sounds good but I was thinking about graphite. Your opinions please.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 16 (permalink) Old 11-19-2015, 05:12 AM
First Name: Earl
Clean & paste wax. Johnson's or equivalent with NO additives, especially no silicone. In the furniture polish area NOT the automotive aisle. Also is a great final finish for wood.
earl
post #9 of 16 (permalink) Old 11-19-2015, 11:18 AM
The graphite will come off on everything, Don. Too much bother trying to avoid transferring the black stain.
BrianS and schnewj like this.
DaninVan is online now
post #10 of 16 (permalink) Old 11-19-2015, 08:56 PM
Nononononoonononnonononononoooooooooooooooooooo!!! !!!!!
you will hate you if you use graphite...
go w/ the wax.....
schnewj likes this.
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
