Hitachi M12v2 Bogging Down - Router Forums
 4Likes
post #1 of 16 (permalink) Old 11-18-2015, 10:43 PM Thread Starter
First Name: Darrell
Default Hitachi M12v2 Bogging Down
I have a M12v2 Router that runs fine til under load. It bogs down. The variable speed wheel does not work either.
Any ideas?
darrells81 is offline
post #2 of 16 (permalink) Old 11-18-2015, 10:51 PM
capacitors in the speed control...
control wheel not connected to the speed pot...
needs new brushes...
post #3 of 16 (permalink) Old 11-18-2015, 10:59 PM
Welcome to the forum Darrell. All of Stick's suggestions are good possibilities.
darrells81 likes this.
post #4 of 16 (permalink) Old 11-19-2015, 07:25 AM
First Name: Art
I have a spare V12 (it's a spare because I burned the speed controller out). I bypassed the speed controller and use an external one from Harbor Freight. I have noticed that although it works fine that I can bog it down when I press hard. From your description I would say that you need a new controller. A internal controller is almost as much as a new router.
mgmine is offline
post #5 of 16 (permalink) Old 11-19-2015, 10:06 AM Thread Starter
First Name: Darrell
Thanks everyone!
That's what I was thinking, but it's great to get advice from ones who have walked a little farther down this road!
I am going to bypass the controller, check the brushes and see what happens.
I am setting up shop and wanted a good workhorse in my router table I just built. Bought this M12v2 off Ebay, I wasn't too surprised to find this problem. But the seller never mentioned this issue!
post #6 of 16 (permalink) Old 11-19-2015, 11:00 AM Thread Starter
First Name: Darrell
So, I checked the brushes, they look good.
I looked at the controller, and quickly figured out I am not versed in messing with it!
How in the world do you bypass this thing? I can see the black and white wires coming out, probably need to be connected. But it also has a red wire by itself, coming from the power switch. And a bundle with red, black and white coming out and going to the variable speed dial on the handle.
Would I cut and cap the single red wire. And unplug the 3 wires going to the speed dial. Then connect the black and white larger gage wires together?
I will get a variable external controller later, if I can achieve this step!
Thanks for any help guys!
post #7 of 16 (permalink) Old 11-19-2015, 11:27 AM Thread Starter
First Name: Darrell
I took a picture to detail the innards.
1 & 2 are the main power, and I am guessing that I would just need to connect them together.
3 is coming from the power switch, was thinking it just needs cut and capped?
4 just needs unplugged.
Are these what you'd call proper procedures?
Thank you for your prompt answers!
post #8 of 16 (permalink) Old 11-19-2015, 11:53 AM
First Name: Phillip
Originally Posted by darrells81 View Post
Thanks everyone!
You should consider contacting the seller. It may be used, but sellers may not pass off broken items as functional. Ebay will guarantee your purchase.
To change the world, change your mind.
phillipdanbury is offline
post #9 of 16 (permalink) Old 11-19-2015, 12:32 PM Thread Starter
First Name: Darrell
I got it cheap. So like I said, I wasn't surprised. I am not happy that they didn't tell me the truth of the matter. They had to have known! I can't go through the down time now. I wanna fix the issue and move on.
I need to get set up quick, orders are piling up....I got work to do! lol
Thanks for the advice Phillip.
post #10 of 16 (permalink) Old 11-19-2015, 06:08 PM
TenGees's Avatar
First Name: Paul
Darell, I can't figure out what is what from the picture but you basically want it like in the diagram. I'm not sure if the included switch will handle the motor current. You could bypass it too but that might be dangerous unless maybe the router is in a table with a switch.
TenGees is offline
Hitachi M12v2 User Unite! Dwain Lambrigger Table-mounted Routing 11 01-27-2012 03:37 PM
Hitachi M12V2 plunge lock problem to avoid AlanWS General Routing 1 03-25-2011 07:57 PM
Router Hitachi M12V2 Manual Manuals Hitachi Manuals 0 12-16-2010 12:33 AM
Router - Hitachi M12v2 or Triton 3 1/4 hp janthem Starting Off 6 08-10-2008 08:27 AM
hitachi m12v2 router fence cabin General Routing 2 11-30-2007 11:36 PM
