Hand Router trouble. - Router Forums
 19Likes
post #1 of 19 (permalink) Old 11-19-2015, 07:20 AM Thread Starter
Default Hand Router trouble.
Hi. Im trying to cut 18mm hardwood using a template which has curved random edges. I'm using a Dewalt Hand router and cheaper hand router.
I'm using a flushtrim cutter bit. The wood has been band saw cut to with in 2mm from line of cut.
The problem i'm having is, I press the bottom plate of the hand router as flat as I can on the template as i'm cutting, but occasionally (particularly on thinner part where the template doesn't give much area for the router base to sit on) the whole router 'rocks' and causes the cutter to make indents into the road of travel.
The dewalt is at least a bit better as it has a larger flat edged base. The cheaper one has a round base which is easy to rock out of upright position. but nether of them is ideal.
I find the hand routers easier to handle, but would a table router be a better idea?
Thanks in advance for any advise.
Victor16 is offline
post #2 of 19 (permalink) Old 11-19-2015, 07:34 AM
CharleyL's Avatar
First Name: Charley
A larger router base would help. They make some that are kind of tear drop shaped with a handle attached to the narrow end and the router attached to the larger round end. Keeping the end with the handle toward the center of your template as you make the cut and holding it down by this handle will keep the router from tipping.
Offset Router Subbases
Charley
Yaka, Victor16, ksidwy and 3 others like this.
Central North Carolina
CharleyL is offline
post #3 of 19 (permalink) Old 11-19-2015, 07:56 AM
DonkeyHody's Avatar
First Name: Andy
A router table would definitely help your problem of the router rocking on the edge. A larger base will help too, like Charley said.
You can find something that's the same thickness as the template plus the workpiece and lay it on the workbench in such a manner as to support the outside of the router base. That's a quick and dirty solution. Of course you'll need to raise everything off the bench enough to keep the bit from cutting into the table. But you'll get better at holding it straight with practice, anyway, which is probably not what you want to hear right now.
Victor16, ksidwy and hawkeye10 like this.
DonkeyHody is offline
post #4 of 19 (permalink) Old 11-19-2015, 09:01 AM
DonkeyHody's Avatar
First Name: Andy
OK, here's what I was trying to put into words in my last post. It won't require you to buy a router table or even a new base. (But I wouldn't want to deprive you of the excuse for a new tool.) Get a piece of foam board or something thick enough to keep your router bit off the workbench. The rest can be scraps you already have.
Name:	Router template2.jpg
Name:	Router Template.jpg
Victor16 likes this.
post #5 of 19 (permalink) Old 11-19-2015, 10:59 AM Thread Starter
Thank you for your ideas chaps.
I think a basic router table is on the cards.
That's good alternative Donkeyhody. Thank you for the diagram.
Other problem is I use small g-clamps (to hold template to timber), so have to keep moving them as I go round job.
Victor16 is offline
post #6 of 19 (permalink) Old 11-19-2015, 11:12 AM
on the clamps, use a thin double backed tape, you will not be moving the position of the template and will make a continuous cut, it will improve your experience greatly. Also if you use a router table to template route you will most likely have to use the DB tape.
ksidwy likes this.
Herb Stoops is offline
post #7 of 19 (permalink) Old 11-19-2015, 12:54 PM
Bodger96's Avatar
First Name: Bob
I have used an offset base with great results. I would not let anyone take my router tables away. Hot glue will also work for holding templates.
Regards Bob
ksidwy and Herb Stoops like this.
Bodger96 is offline
post #8 of 19 (permalink) Old 11-19-2015, 06:36 PM
DonkeyHody's Avatar
First Name: Andy
Definately get some double-sided tape. It'll just simplify your life.
ksidwy likes this.
post #9 of 19 (permalink) Old 11-20-2015, 04:57 AM Thread Starter
Will it stick to MDF without making a mark on it after its taken off?
Victor16 is offline
post #10 of 19 (permalink) Old 11-20-2015, 06:03 AM
hawkeye10's Avatar
First Name: Don
No it will not make a mark on MDF when you take it off. Please get a router table, it is one of the best tools in my shop.
ksidwy likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Trouble with pages, am I the only one? Jack Wilson Lobby 6 06-20-2015 01:22 PM
trouble with vcarve stillakid CNC Routing 3 08-11-2014 11:34 AM
Tongue & Groove trouble Sgt Pepper General Routing 7 02-26-2011 11:39 PM
Trouble with Tear-out...Help! rpoulson Table-mounted Routing 10 01-01-2010 03:12 AM
Dovetail trouble Drick Table-mounted Routing 2 06-02-2005 03:38 PM
