High speed steel bits. - Router Forums
 2Likes
post #1 of 13 (permalink) Old 11-21-2015, 01:00 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default High speed steel bits.
In doing inlays I am using 1/8" solid carbide bits. I am doing the inlays in red oak and I think I am getting little bits of waste between the bit and the bushing causing the bit to brake when I am cleaning out for the inlay. I am going slow so I don't believe I am pushing to fast. I was thinking about using HSS bits because they are cheap. What do you guys think?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 13 (permalink) Old 11-21-2015, 01:05 PM
Honored Member
First Name: pat
Solid carbide is much stiffer than HSS.
Would not use the steel cutter.
What is the depth of cut here?
Quillman is offline
post #3 of 13 (permalink) Old 11-21-2015, 01:34 PM
If you think it's the bushing causing it can you switch to a larger bushing? Also, is the bit an up spiral? If so a straight bit might work better.
post #4 of 13 (permalink) Old 11-21-2015, 01:54 PM
PhilBa's Avatar
First Name: phil
For other than spirals, carbide rocks and I would never use anything else. Unfortunately, carbide spirals are always solid carbide and very brittle. It's really easy to break them. I have an HSS 1/4" spiral that has lasted an amazingly long time. It's getting a little dull so I replaced it with a carbide bit. Broke it right away not really pushing it at all. Got another. It broke as well with a fairly light load. So, yeah, HSS spirals have their place.
But, I don't use spirals for an inlays, just straight, non-plungable carbide bits. They work fine and I just have to move the bit around to get it "plunged". Since I'm typically going in less than 1/16" deep, it's not a big deal.
Visit my shop website.
PhilBa is offline
post #5 of 13 (permalink) Old 11-21-2015, 03:06 PM
Onsrud still makes quite a few HSS bits and they recommend using them in quite a few cases. Although they don't stay sharp for as long, HSS bits can be sharpened sharper than carbide because of the grain size difference.
post #6 of 13 (permalink) Old 11-22-2015, 08:39 AM
First Name: Dennis
For cutting out the inlay I use downcut 1/8 carbide and the only problem is heating because the material jams into the cut slot instead of being blown out. I just go slow and everything works out. I've been thinking of using dense foam instead of MDF for the sacrificial face but hav
en't tried it yet. I think it may not jam material in the slot as badly using the downcuts. I prefer the downcuts as the leave a perfect top edge on the positive inlay that is necessary for a clean tight fit. For cleaning out the negative side of the inlay I use a 1/4 carbide with a larger bushing size sufficient to leave about 1/16 inch around the outside edge that is finished off with the 1/8 carbide bit . This makes cleaning the larger cut outs much faster and no bit breakage. By taking out the middle with the larger bit ffirst it also makes the 1/8 inch run to clean up the edge very easy and is necessary to match the positve inlay which was cut out with a 1/8 bit. I usually use two routers as changing out bits and bushings on the same cutout makes it difficult to get exact depth matching on the two bits. The other thing of course is that the two runs have to be done with the pattern being held securely in place with no movement during the whole process. I usually use up cut spirals on the cutout 1/4 inch. I also have a dust removal kit on the router which helps big time in removing any debris that is brought up.
routergieck is offline
post #7 of 13 (permalink) Old 11-22-2015, 11:34 AM Thread Starter
hawkeye10's Avatar
First Name: Don
You are right carbide is hard, stiff, and it's also brittle and that is the reason I had thoughts on using HSS bits. The HSS bits are cheap and if they get dull or break it doesn't cost that much to get another. What I am concerned about is the quality of cut. My depth of cut is 1/8".
post #8 of 13 (permalink) Old 11-22-2015, 12:40 PM
add an air coolant hose/nozzle...
Adjustable Hose Sets | Travers Tool Co., Inc.
post #9 of 13 (permalink) Old 11-22-2015, 12:45 PM
bcfunburst's Avatar
First Name: Reg
I have done my inlays of padauk in maple, always using up-cut 1/8" Spiral bits from Whiteside. I use a VERITAS RT and pin arm system for inlay. The Whiteside bits seem to last much longer in Maple. I found it is much easier to do a fine clean cut with these bits, even for clean out. I just go slow with a shallow 1/8" depth for inlay, and do a second cut , deeper if you want to make the inlay thicker for a cutting board, etc.. VERITAS Tools are available @ Lee Valley Tools.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #10 of 13 (permalink) Old 11-22-2015, 12:46 PM
I saw some pictures on ebay of a guy trying to sell some HSS Onsruds and they cut ash as smooth as a baby's rear end.
New member in Takoma Park MD and router table question Keith C New Member Introductions 15 09-23-2015 05:51 PM
new guy from indy mattinindy New Member Introductions 14 09-17-2015 04:58 AM
New convert jgregg078 New Member Introductions 8 09-01-2014 05:11 PM
Whiteside dovetail bits not lasting long for me AronD Router Bits - Types and Usage 20 04-15-2013 01:17 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
