Holding small parts. - Router Forums
 4Likes
  • 1 Post By vchiarelli
  • 1 Post By Cherryville Chuck
  • 1 Post By hawkeye10
  • 1 Post By Stick486
post #1 of 10 (permalink) Old 11-29-2015, 08:22 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Holding small parts.
How can I safely hold odd shaped small parts when routing? I have been making some piggy banks for Christmas presents and I don't like holding the pigs ear by hand. My fingers are awful close to the bit. Suggestions please.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 10 (permalink) Old 11-29-2015, 08:46 AM
First Name: Richard
Can you shape the ears on a bigger piece and the cut the ears off?
Shop guy is offline
post #3 of 10 (permalink) Old 11-29-2015, 09:23 AM
vchiarelli's Avatar
First Name: Vince
@hawkeye10
Don: looks like the ears are concave, with a slight round over on the outside. I'm not sure I'd attempt this with a router. I'd be more inclined to do some hand work on the ears - gouge out the inside, then perhaps a rasp or file and some sandpaper to clean them up. Might take a little more time but would certainly be a lot safer.
Nickp likes this.
vchiarelli is offline
post #4 of 10 (permalink) Old 11-29-2015, 10:17 AM
Don you didn't say if you are doing these on the RT or handheld but it's a job I wouldn't do on a table. I would try and make a hollow in a piece that I could set the ear into and route by hand. Maybe a little double sided tape to help hold it down.
How have you been doing it so far?
post #5 of 10 (permalink) Old 11-29-2015, 10:50 AM Thread Starter
hawkeye10's Avatar
First Name: Don
The ears are made of 3/4" pine and cut out on a band saw. I then round the edges on my router table and use a spindle sander for the concave. I don't route the bottom of the ears so I can attach them to the head. I really don't like routing them by hand, in fact I will not do it again. It scares me and I am not scared of anything.
post #6 of 10 (permalink) Old 11-29-2015, 11:49 AM
The spindle sanding is the safest operation. I thought that was the problem and that you were doing it with a router. You could make a holding jig that would allow you to use it to push the ears through. I would use a board with 3 or 4 screws sticking through about 1/8" and put a handle on it. The pin holes from the screws would be sanded out when you use the spindle sander. Use screws with really sharp points like drywall screws. The ones that usually come in spar packs are about as dull as butter knives.
Moz likes this.
post #7 of 10 (permalink) Old 11-29-2015, 12:22 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Thanks Chuck. You seem to have good answers to problems folks have on this forum. I know I appreciate your knowledge and time on helping us out.
gomolajoe likes this.
post #8 of 10 (permalink) Old 11-29-2015, 01:37 PM
CharleyL's Avatar
First Name: Charley
For rounding the pig's body, head and maybe even the nose I would use a router table and a non slip gripping pad like the one in this link Grr-Rip Block? Smart Hook Push Block (GB-1) | Rockler Woodworking and Hardware . Press down on the gripping pad against the top of the piece being routed and guide the piece along the round over bit. For the ears I wouldn't use a router at all. I would use a sander and maybe a non slip glove for the hand holding the ear. If you draw the ears on a piece of wood and hollow them out with a Dremel or curved carving chisel before cutting them out it will be easy to clamp the board in a vise for this step. After cutting them out rounding the edges with a sander will be easy and relatively safe. Of course, you could hand sand them and be even safer.
Charley
Central North Carolina
CharleyL is offline
post #9 of 10 (permalink) Old 11-29-2015, 03:23 PM
dremel and burr bits...
Herb Stoops likes this.
post #10 of 10 (permalink) Old 11-30-2015, 09:09 AM
Cut the ear shape on the end of a longer piece on the bandsaw. Use a wooden vise to hold onto the un cut long portion. Roundover the ears using a bit with a bearing and hold on to the wooden vise to guide the longer piece. Dremmel with burr bit to shape the indent. Spindle sander to cleanup the indent and shape the back side of the ears. Mark and then cut off the ear so you can attach it. Hands stay safely away from the bit throughout the whole process.
How to route small parts safely SteveMI Table-mounted Routing 22 10-02-2015 03:06 PM
Laminate trimmer versus light router - cutting out small parts from sheet?? vandomme2 General Routing 13 11-05-2012 09:24 AM
Small profile holding idea Bob N Jigs and Fixtures 8 10-30-2009 01:25 PM
Craftsman parts issue - Canadian 24604 db9 General Routing 8 10-11-2009 07:44 PM
router parts search joromu55 General Routing 3 06-26-2008 08:58 PM
